Re: cryogenics ?
[Re: MRMOPAR]
#1223037
04/28/12 03:39 PM
04/28/12 03:39 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Wonder if iron blocks would benefit? Pretty much need to come up with some kind of vessel or cooler. We vent of liquid all the time. Just need to make something easily taken apart, and hook up a 1/2" line and valve, then on the other end hook up a vent/purge or outlet line... Basically just crack the inlet and leave the outlet all the way open. How much the inlet is cracked will result temp drop or cool down period/rate. Once you see liquid coming out the outlet you know the inside is as cold as the liquid.. Just close the outlet at this point. The vessel would need to be made of stainless or aluminum to keep from cold imbrittelment. Maybe I should start doing this, and maybe offer to do this for fellow racers for a small fee.. If they would be a interest.... Small parts, like cams, and lifters with very little setup... But for blocks and cranks I would need a vessel.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
Re: cryogenics ?
[Re: Bob_Coomer]
#1223038
04/28/12 11:39 PM
04/28/12 11:39 PM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
chyro was .developed for machine cutting bits during the world war..turning bullet and shell casings in a mass production..chryo treated lasted measurably longer.. in the 90s i raced and worked on professional roadrace motorcycles..we had a all kinds of stuff chryo treated..gearboxes cranks valves cams.. even the aluminum frames but things like cyl walls that have to be machined afterwards created some problems... the cutting speed truning cranks and boring ect. had to be adjusted...because its alot harder to machine a chryo part.. also you have to re-clearence after chryo treating.the dimensions of the part can change afterwards..fwiw. it works there is no doubt about it.
the way i understand it the freezing slows down the molecules and allows them to align into a more uniform structure which is where the strength comes from
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
Re: cryogenics ?
[Re: hemidup]
#1223039
04/29/12 10:27 AM
04/29/12 10:27 AM
Posts: 2,129 Vermont
TrWaters
Vermont
I cyro'd every internal part in my engine, valves, springs, rod's, piston's, rings, bearings, crank, ARP main and head stud's etc plus the block. Cheap insurance.
Tell the truth Jerry....you live in Minnesota. You just left your stuff outside a couple January nights.
