Re: new sb 5.9 build pushing oil out everywere?
[Re: F. Sadler]
#1222825
04/27/12 09:41 AM
04/27/12 09:41 AM
Posts: 2,826 NY usa
540challenger
NY usa
just built my 5.9 360 magnum,and i have oil comming out of the oil breather and the dipstick tube..its a full roller motor with e/b rpm heads,kb 107 pistons ,comp cam 180 ..i'm buying a new dipstick tube tomorrow to see if that helps,also buying a pcv valve,but dont think thats the problem because it rattles when i shake it and it does have suction wile motors running..what else should i check for??
I hate to say it but .....it sounds like a broken ring. Do a compression test and a leak down test.
[Re: F. Sadler]
#1222826
04/27/12 01:33 PM
04/27/12 01:33 PM
Posts: 2,356 Kentucky
dfsmopars
Kentucky
I JUST completed a 5.9 Magnum build as well. Very similar build to yours but thankfully without blow-by. Your situation sounds more serious than a dip stick or PCV valve. I first cranked mine up without crankcase ventilation and it blew a small amount out of the oil fill cap but nothing out of the dipstick. I added a PCV valve and two filtered breathers and there is no oil anywhere coming out. I'm not a professional builder so I am only sharing my current experience with you. Good luck and I hope it isn't too serious.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring ‘14 Big Horn, Quad Cab, 4x4, 1500
[Re: 540challenger]
#1222827
04/27/12 01:34 PM
04/27/12 01:34 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
what kind of rings did you use? how many miles on rebuild?
as stated,, it sounds like a broken compression ring or the rings are not seating/sealing.
I am truckless..
[Re: dogdays]
#1222830
04/27/12 04:49 PM
04/27/12 04:49 PM
Posts: 18,160 Mass
DAYCLONA
Mass
Save your money on the dipstick. That isn't the problem. If the PCV valve is working and hooked up, and you're still building pressure in the crankcase (oil squirting out everywhere is the first clue) then your new rings didn't seat. You're going to be taking the engine down to replace them and hone the cylinders with the right stone for the rings you choose.
Sorry, R.
......Another reason the rings my have not seated, they could be hung up (compressed) in the ring grooves and never expanded after you compressed them to install in their bores, happens sometimes with used pistons if the grooves weren't recut, or you have the wrong rings (thickness wise) one of those things you have to know/check during assembly ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: F. Sadler]
#1222831
04/27/12 05:15 PM
04/27/12 05:15 PM
Posts: 2,091 Delray beach, Florida
Performance Only
were the cylinders bored/honed the proper way, or just dingleberry honed? new rings or used?
machine shop owner and engine builder
[Re: F. Sadler]
#1222834
04/29/12 11:45 AM
04/29/12 11:45 AM
RapidRobert
top ring gap is .0065" per inch of bore. Did you do the 25 minute 2500 rpm breakin?
[Re: F. Sadler]
#1222837
04/29/12 01:46 PM
04/29/12 01:46 PM
Posts: 21,091 Niles , Ohio
therocks
Niles , Ohio
You need a leak down detector to do the test.It put air pressure in the cylinder and you see how much leakage there is on the gauges.Sounds like you have some problems that might be serious.I rebuilt my 440 and the kids 360.Both run just 2 breathers and neither pushes out oil.They both hit 6500 on a regular basis.Mine has forged domes and the 360 has KBs.Rocky
Chrysler Firepower
[Re: F. Sadler]
#1222839
04/29/12 02:29 PM
04/29/12 02:29 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
This is why you should not switch pistons with out boreing the engine.
With 20,000 miles there is still gonna be some distortion near the top of the bore, might be very small but it will be there. Now you have swapped pistons and the KB 107 has a higher ring grooove than the old pistons because the compression height is higher, now your top ring is traveling past this distorted area of the bore and unseating loseing cylinder preasure (exacerbated by the very high dynamic compression), the only way to fix it is go back to the stock pistons/rings or bore it to get nice straight bores with new pistons and rings. You could just drive it like this and it may wear to a point it seals a little better but it will never quit entirely till it is fixed.
