Re: Best place to buy new motor mounts? [Re: jrwoodjoe] #122129
09/18/08 08:30 AM
09/18/08 08:30 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
There isn't a good quality mount available from any parts store that I know of anymore. I've been round and round with the junk from India and Korea. The rubber is bad and the metal parts don't fit.
I'm going through an issue with a 94 LeBaron trans mount right now and I suspect in the end the kid who owns the car will end up buying the factory mount for $200.
I am going to need new motor mounts for the 340 to go in my Challenger when done. Jim, are you saying that you can't get a good motor mount that looks like factory any longer? How different do the Shumacher mounts look from stock?
Thanks, Joe
The Shumacher poly has a gold irridated bracket that goes on the frame and the poly looks different than the rubber , just spray it black and be done with it.
Re: Best place to buy new motor mounts? [Re: 67SATisfaction] #122130
09/18/08 10:23 AM
09/18/08 10:23 AM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
I second this opinion - been trying to source OEM style BB mounts. I get the same #%$^& part number from India. The steel nub doesn't line up with the hole. There must be thousands but the sales rep swears they never had any returned. ^#&*%* Sent back twice to Mancini before I gave up, once to Summit for the same reason.
And we continue to out-source When is America going to wake up a smell the coffee. You'd think there would be more complaints. Perhaps we aren't complaining LOUD enough
Scott steps down from his soap box
Re: Best place to buy new motor mounts? [Re: Scott Carl] #122131
09/18/08 02:59 PM
09/18/08 02:59 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Outsourcing doesn't bother me as much as it does some others. Much of the industry that I've been connected with most of my life (electronics) was outsourced a long time ago, but quality is there. I think they get away with it on parts like motor mounts because a lot of people don't change them when they wear out and they aren't "visible" to the average car owner. Complaining at the parts store seems to be futile.
Re: Best place to buy new motor mounts? [Re: Y3 70 BEE] #122132
09/18/08 03:07 PM
09/18/08 03:07 PM
So Cal, USA
Fab64 Offline
Fab64  Offline
So Cal, USA
New or old car its INDONESIA mounts. Moroso solid cheap and reliable.
Please elaborate. Are you saying that Moroso mounts are made in Indonesia, and that they're good?
Re: Best place to buy new motor mounts? [Re: Scott Carl] #122133
09/18/08 03:14 PM
09/18/08 03:14 PM
Anywhere the British Secret Se...
Moonraker Offline
Moonraker  Offline
Why complain? When its American made its usually expensive as hell and people complain about the price . In most peoples mind its better to buy crappy parts for cheap then buy quality parts that are expensive. Also why pay an American $20 an hour to build the same thing you could get someone in a poor country to do for 20 cents a day. Yes its sad but unfortunately thats the world we live in.
Re: Best place to buy new motor mounts? [Re: dustergirl340] #122134
09/18/08 05:32 PM
09/18/08 05:32 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
thanks guys...looks like we're going with the Schumachers
Word of warning...His HD poly units are taller than stock. If your clearance to the hood is tight, 0.25 or less, they may not work. I was told they are the same thickness as stock, but they aren't. I guess he can't read a set of calipers. My air cleaner now rubs the hood. I was going to swap out the high dollar hd poly ones for solids and see its lower, just havent got around to calling him back.
Re: Best place to buy new motor mounts? [Re: Dragula] #122135
09/18/08 06:50 PM
09/18/08 06:50 PM
Chicken coop
dustergirl340 Offline OP
Chicken Little
Chicken Little
Chicken coop
Thanks for the heads-up. Though we have plenty of clearance, it shouldn't be a problem.
Re: Best place to buy new motor mounts? [Re: dustergirl340] #122136
09/18/08 07:52 PM
09/18/08 07:52 PM
Rohnert Park, Ca
ryan053 Offline
ryan053  Offline
Rohnert Park, Ca
I just bought the cheap ones from the parts store and drilled 2 holes through the drivers side mount and bracket. then put two grade 8 bolts through it and its holding up fine for me.
Re: Best place to buy new motor mounts? [Re: ryan053] #122137
09/18/08 08:16 PM
09/18/08 08:16 PM
BDW Online content
BDW  Online Content
Sounds interesting, got a pic?
Re: Best place to buy new motor mounts? [Re: Dragula] #122138
09/18/08 10:01 PM
09/18/08 10:01 PM
Montana
P
Posest Offline
Posest  Offline
P
Montana
I bought a set and they are identical thickness to the ones I replaced. I like the lock on the drivers side. Even if it deteriorates the lock will keep the engine from trying to flip over. I received a bad passenger side mount and called the about it. I had a new one two days later for free. No questions asked. Schumachers is the only place for me to get my motor mounts. In fact I used their kit to convert my 4 cyl Dakota to a small block. Bolted right up and have had no troubles with it at all. Very happy with the quality and pricing.
Re: Best place to buy new motor mounts? [Re: 540challenger] #122139
09/19/08 08:30 AM
09/19/08 08:30 AM
Minnesota
snojet Offline
snojet  Offline
Minnesota
Dose anybody have the web site for Schumacher?
Re: Best place to buy new motor mounts? [Re: snojet] #122140
09/19/08 08:41 AM
09/19/08 08:41 AM
md
mopars4ever Offline
mopars4ever  Offline
md
Schumacher Creative Services Engine Mounts - Parts Department
Lock It Down
New Custom Car Parts Accessories Engine Mounts
If you're building a new engine for your ride, and you're thinking about reusing your OEM engine mounts in that '67-'72 A-Body, '62-'72 B-Body, '66-'73 C-Body, any year E-Body, '72-'92 Dodge Ram, or D-Series fullsize truck, you're asking for trouble. Those mounts have endured enough over the years, and they're likely to break and set your engine to dancing by itself under your hood. Save the trouble and get a set of Magnum Polyloc engine mounts from Schumacher Creative Services. They're 100-percent American-made with a unique heavy-duty interlocking feature that keeps the mount from pulling itself apart. Use these when installing your LA, B/RB, or 426 Hemi, and it'll stay put for good. Plus, the polyurethane insulation minimizes engine vibrations transmitted to your chassis.
Get It: Schumacher Creative Services
206/364-7151
www.engine-swaps.com
Re: Best place to buy new motor mounts? [Re: mopars4ever] #122141
09/19/08 08:51 PM
09/19/08 08:51 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Only stock style ones I have had good luck with were Borg/Warner & TRW and I'm not sure they make them anymore. Last ones I bought were in 1990.
I will probbly get the poly locks and a torque strap.
Re: Best place to buy new motor mounts? [Re: 451Mopar] #122142
09/19/08 08:54 PM
09/19/08 08:54 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
I've broken the cheap PIONEER ones twice now.
I've got Morso Solid mounts, but I'm going to try the rubber/solid combination.
If only I found find a reasonably priced rubber mount that wouldn't break...
Truth be told, I will more than likely end up with Polylocs.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
