Re: rb external oil pump ?'s
[Re: 52savoy]
#1220362
04/24/12 07:05 PM
04/24/12 07:05 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
I have 2 questions while we have some knowledgeable people talking oil pumps? 1.- What does everyone think about the new design milodon pump,Good or Bad? 2.- I am thinking of maybe using the milodon part # 21815, Good or Bad choice?
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: hemi-itis]
#1220365
04/24/12 08:38 PM
04/24/12 08:38 PM
MRMOPAR622
Sweet Home Alabama
The 21815 (left out the 1 the 1st time)pump has the dual inlet doing away with the need for the plate between the pump and block,also it looks like the vane and rotor are different from the older ones. My milodon from a few years back had the plate between the pump and block for the 2nd line.
[Re: jamesc]
#1220368
04/25/12 02:05 AM
04/25/12 02:05 AM
Posts: 782 wine country
8urvette
wine country
um...forgive me for asking the stupid question but if the threads are damaged enough that they can't be used for a hose fitting how are you going to cap it?
about 25% of the threads are toasted, only on one side.... so 1/4 of the round part is messed up... when i said cap I was thinking tig it shut with a plug. in my head i pictured what i wanted, in the forum i sounded stupid
my worry is leakage if i run the external pickup... if its plugged i can replace it at a later time, if i ever decide too.
