Re: Six Pack stroker way too rich?
[Re: Mr.Yuck]
#1219919
04/25/12 06:52 PM
04/25/12 06:52 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
pull the sensor and clean it off. Not sure how the tach works w/ the MSD unit. No real reason the 440Source unit shouldn't work. I have a MP unit with the light Mr. Gasket springs. What plugs are you using? Might hey be too cold? I judge my a/f by reading a few plugs at the end of a pass...lol
screwing around with timing/dist. is not going to solve your richness issue. how do you have your outboards set at idle? what plugs are you using? to answer the question on the timing light, is the ready to run MSD a mulit-spark Capacitor discharge ignition unit like their ECU's?
[Re: mikemee1331]
#1219920
04/25/12 08:53 PM
04/25/12 08:53 PM
Posts: 4,318 Prospect, PA
BSB67
Prospect, PA
In light of the OPs question, I'm going out on a limb with mikemee1331 in making the crazy assumption that maybe it's rich. I suggest leaning it out.
Here is a thread started by Wayne Smothers. It is very very insightful. Read it. If you don't understand it, you probably should not be messing with the carbs - get some help, or spend some time understanding all of the functions of each carb, and how each of those functions interact under different driving conditions.
Good luck.
https://board.moparts.org/ubbthreads/show...rue#Post7017997
[Re: RobX4406]
#1219922
04/27/12 05:07 PM
04/27/12 05:07 PM
Posts: 37 Minnesota
Shawnb
Minnesota
So we added the NEW NEW carbs. They came from the carb shop and seem to work great. Cleaned off the O2 sensor. Still running 10-11:1 air fuel. Little rich but power is way better than it was. At the same time we removed the $79 cheapo dist from 440 source and added the MSD ready to run. With the built in curve it seems to get 34 degrees which is the total advance that gave us the highest torque (715) and the idle is 15. Is that too low? Should I have work done to the dist or can I set that myslef with adjustments on the new dist?
[Re: Shawnb]
#1219929
04/30/12 02:51 PM
04/30/12 02:51 PM
Posts: 43,263 Bend,OR USA
Cab_Burge
I guess at this point my biggest question is 10-11:1 air fuel ratio still too rich? I cleaned off the O2 sensor. It is very responsive and seems to work properly. Should I trust it? If so might I still damage the engine?
That is way to rich, it will foul plugs and can damage the cylinder walls. Check your manifold vacume in gear and then check the power valve rating, report back It sounds like the power valve is opening at cruise RPM, maybe not While you have the center carb off and apart look at the main jets and tell us the size on them also I've used, tuned and successfully race a six pak for 5 yrs, street motor on pump gas, 10.34 ET at 128.6 MPH cork up on pump gas in a 3450 lb Duster on street legal M/T Radials I made mine idle at or above 14.8 AFR and drive at between 13.8 to 14.9 AFR at light throttle with the power valve closed at or above 2000 RPM to 3000 RPM I have now(this year) switch heads to a set of Indy SR M.W. port size with a Indy 400-3 intake and 1050 Holley Dominator carb, I have it set up to idle at 14.8 to 16.1 and drive at low RPM, below 2000 RPM, around 15.0 and above, I'm still working on it so it may end up a tiny bit richer than it is right now as it does have a lean stumble coming off the idle circuit,especailly when cold not good Carbs are harder to tune than EFI, you got to take them apart to work on them and make changes
Re: Six Pack stroker...I am putting a 541 6bbl together
[Re: Cab_Burge]
#2911565
04/18/21 10:40 AM
04/18/21 10:40 AM
Posts: 100 Louisiana
BiomedTechGuy
Louisiana
Yes, I'm resurrecting this thread because I have a new Bill Mitchell aluminum big bore RB block, and it's the foundation for a 541 6bbl build. Mostly street cruising including Power Tour desires, other highway trips, stop and go traffic, and definitely 1/4 mile grudge racing. All for fun. Keeping the 6bbl is a MUST, my personal choice. All 3 Holley carbs are modded with Promax parts, everything except the fuel bowls. That will make tuning changes easier. Innovate Motorsports 2 channel wideband O2 sensor system is onboard and works GREAT. It seems to me like running TF240s on a 541 wouldn't make sense, so I'm planning on the 270s. Goal is 700 ft lbs torque across as flat and wide an RPM range as possible and let the horsepower fall where it will. I'm hooked on my N96 hood, so I'm inclined to run the Modman intake with the 6bbl top and port it to MW port size for the 270s. Chassis, suspension, and drivetrain already setup for the power of the stroker. I'm running a Passon Performance 855 5 speed. All comments welcome. Thanks.
[Re: BiomedTechGuy]
#2995241
12/14/21 01:02 PM
12/14/21 01:02 PM
BiomedTechGuy
Louisiana
BUMP hoping for some feedback. I also re-read the entire thread, I'm wondering what happened with the rich (10-11:1 AFR) condition on the OP's stroker. What a FINE looking couple of B-bodies! Anyway, current "plan" is to go to the Indy ModMan intake as it is mandatory that my setup be a 6bbl and fit under the N96 hood, and have the Air Grabber functional, even though I may have to do modifications to it. I also want to run a K&N oval air filter as it is significantly taller than the factory unit, and is the only way I'll be able to feed a 541 enough air. 700 ft lbs torque is my power goal, as flat and wide as practical, and I'm sure the horsepower will fall in the 6XX range. Does anyone know if Hughes still does the "Stage X" (Stage 2 porting was mentioned) of the aluminum 6bbl intake? I can't see using TF240s on a 541, it seems like the Max Wedge port size is a given, and Indy has a CNC program for their ModMan intake that takes it to Max Wedge port size. The other 2 intakes I have for a 6bbl are my Edelbrock factory 2 plane 6bbl and the Weiand P3690982 6bbl intake from the 70s, "Cross Flow" I believe it was called, but either would have to be ported to Max Wedge port size.
[Re: BiomedTechGuy]
#2995284
12/14/21 03:12 PM
12/14/21 03:12 PM
Posts: 4,743 Moved to N.E. Tennessee
GomangoCuda
The other 2 intakes I have for a 6bbl are my Edelbrock factory 2 plane 6bbl and the Weiand P3690982 6bbl intake from the 70s, "Cross Flow" I believe it was called, but either would have to be ported to Max Wedge port size. Neither of these can be ported to MaxWedge size without extensive welding and the Weiand with an airfilter is not going to fit your N96. If you must have a MaxWedge sixpack then just use the Modman,
