Re: How much HP to expect? SB [Re: ohiodemon] #1219116
04/21/12 11:45 AM
04/21/12 11:45 AM
Kalispell Mt.
HotRodDave Offline OP
Kalispell Mt.
Cam has a 110 LSA
Like I mentioned I picked the cam for a 4.25 stroke 340 with regular magnum heads so I did not expect to turn very many RPM. My plan now for controlling it is light weight parts, 8mm stems, titanium retainers on behive springs and some quality custom pushrods.
I am thinking about trying the Lunati Micro-trol lifters to keep it from pumping up. There own literature makes them sound pretty good.
Re: How much HP to expect? SB [Re: HotRodDave] #1219117
04/21/12 11:50 AM
04/21/12 11:50 AM
Kalispell Mt.
Kalispell Mt.
I want an M1 because of the carb for one but also because I had one on a lower compression 360 and seemed to me like it had plenty of TQ even with a 2.76 gear. I can use whatever intake I want includeing an LA because I have a jig to drill the LA intake bolt pattern. This is kind of a budget deal so it would have to be something found cheap on the used market or one I already have (LD 340, or weiand 8007).
