Re: Duster/Demon/Dart Rallye Dash Differences In 70-71?
[Re: CuriousYella70]
#1217879
04/18/12 01:42 PM
04/18/12 01:42 PM
Posts: 1,028 NB, Canada
moparfan53
NB, Canada
Hmm....that is odd! I wonder why no one is reproducing the correct 70 dash then? Also, if the lighter is in the dash itself and not in the ashtray, how is that setup? Do you have a picture of the backside?
No pic of the back but here is the parts book view. As far as the setup there are the lighter parts in the hole and a single power wire connected to the back of the lighter.
Perhaps you could cut the lighter hole in the repro dash.
Hope this info helps.
[Re: moparfan53]
#1217880
04/18/12 03:07 PM
04/18/12 03:07 PM
Posts: 1,152 Colorado
CuriousYella70
Colorado
The 70 Dusters dashes were correct. As mentioned above, that is the lighter to the right of the radio. It was there in 70 (even though there is an empty round hole in the ashtray). In 71 it was moved to the same ashtray hole that was not used in 70. Another Mopar oddity.
You can see the lighter and the empty ashtray hole in this 70 dash pic.
Do you happen to have a close up of the cigarette lighter itself? Now begins the search for the setup! I'm assuming it has a bracket to hold it in the bezel.
#1217881
04/19/12 08:57 PM
04/19/12 08:57 PM
moparfan53
NB, Canada
Here are 3 closeups I took. I think the lighter parts are the same for many years & models except for the knob design/style (on this application the lighter knob matches the other switch knobs). There is no "bracket" to hold it, there is a piece that threads on the socket behind the bezel.
#1217883
04/20/12 06:07 PM
04/20/12 06:07 PM
Posts: 3,403 cheshire, ct
davesmopars
cheshire, ct
if you need any of these parts. i have them all. send me a pm
Keeper of the 440 M code Cuda registry mcodecuda@yahoo.com
#1217884
04/20/12 07:11 PM
04/20/12 07:11 PM
moparfan53
NB, Canada
do you happen to have a picture of that piece or how the whole setup looks from behind the dash by chance? Sorry to be a pain in the rear! But thank you for your help, I really do appreciate you taking the time to get these photos for me!
I do not have any pics of behind the dash.
No problem, glad to be of help!
