Re: 70 gtx steering column
[Re: 70GTXer]
#1216991
04/16/12 07:50 PM
04/16/12 07:50 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
I've heard the length is different, but that's coming 3rd hand and off memory so here's a so that you can get a definative answer. Dave
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: DPelletier]
#1216993
04/16/12 09:03 PM
04/16/12 09:03 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
I've heard the length is different, but that's coming 3rd hand and off memory so here's a so that you can get a definative answer.you sir are correct and win today's prize.
[Re: 70GTXer]
#1217005
04/18/12 12:02 AM
04/18/12 12:02 AM
Posts: 408 Manhattan, IL
SixPackRT
Manhattan, IL
If memory serves me correct....The only thing different is the actual shaft. This of coarse providing that the two columns you have are the same in being either console auto/4speed or column shift. The shaft can be stretched and shortened, but the lower part of the shaft is slightly different if your doing an accurate restoration. The shaft itself is actually two pieces and the upper (steering wheel) parts are the same. I actually had stripped splines on my original steering column shaft (manual) and used the upper shaft portion from a spare (power) column I had. worked perfect. Hope this isn't confusing... Scott
70 Coronet RT 440+6 64 Dodge 330 - Future Hemi Clone 17 Challenger Hellcat - Green Go Driver 86 Buick T-Type Turbo V-6
[Re: 70GTXer]
#1217007
04/18/12 02:19 PM
04/18/12 02:19 PM
SixPackRT
Manhattan, IL
Scott, You will have to disassemble them both a little to remove the shaft. If you have a Factory Service Manual it would help. If not PM me I will scan the pages and send it to you. Scott
