Re: 70 gtx steering column [Re: 70GTXer] #1217010
04/19/12 06:21 PM
04/19/12 06:21 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Pull the turn signals and the snap ring for the top roller bearing. Remove the top collar, sleeve covering the roll pin for the park sprag, pop the pin out and the small 1/2 snap ring and the steering shaft should slide out the bottom.
Re: 70 gtx steering column [Re: Sixpak] #1217011
04/20/12 04:28 PM
04/20/12 04:28 PM
70GTXer Offline OP
70GTXer  Offline OP
This is great.Appreciate all your help.
