Re: Plugs not firing............
[Re: 4BBodies]
#121718
09/16/08 05:57 PM
09/16/08 05:57 PM
RapidRobert
you got a 1/4" spark out of the coil wire to ground when you grounded the neg primary coil wire. Will it spark(out of the same coil wire not a plug wire) when you move the dist back & forth. If so the reluctor/magnetic pickup is good.
[Re: RapidRobert]
#121720
09/16/08 06:04 PM
09/16/08 06:04 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
I recommend finding someone to at least help hands on or have it done. At this point you are so confused and you don't seem to be able to comprehend what is being said. Sorry but call a spade a spade. ![](/ubbthreads/images/graemlins/frown.gif)
