Re: 69 GTX Engine Bay, Whats Wrong With it ?
[Re: JohnRR]
#1216639
04/16/12 10:50 AM
04/16/12 10:50 AM
Posts: 21,533 N.E. OHIO, USA
A12
N.E. OHIO, USA
Can you post a smaller low res picture , that will make it easier to spot what is not correct.
As said 3 speed is an option , it also has the wrong master cylinder cover.
and if it's a disc brake car it's the wrong master cylinder................
My '69 GTX came with a 2-speed wiper system
[Re: A12]
#1216640
04/16/12 10:56 AM
04/16/12 10:56 AM
A12
N.E. OHIO, USA
Which brings up a question since this is the first '68 or '69 B-body that I've owned with disc brakes "could you get non-power disc brakes?" My GTX has power disc brakes; (front discs of course)
[Re: A12]
#1216641
04/16/12 11:00 AM
04/16/12 11:00 AM
Posts: 3,363 DTW
drmopar
DTW
The master may be correct, the cap for sure is wrong. The B body mopars had to have power assist to get disc brakes. The A bodies past 1970 could get disc without power assist. And yes, J25 was optional on B body mopars, but standard on N96 equipped cars.
-------------------- RM27H9G 4 speed F8/tan guts RS27L9G auto B5/black guts WM23H9G auto F5/green guts 2021 Challenger 392 Indigo/black guts 2019 Charger Daytona R/T F8 on black 2018 Ram Sport Hemi 4x4
[Re: blewbyu]
#1216643
04/16/12 11:11 AM
04/16/12 11:11 AM
Posts: 21,485 It's a dry heat
gtx6970
It's a dry heat
ballast resistor, pcv valve, master cylinder cover,ignitiona coil should be green lettering
missing a voltage regulator?
a/c compressor pulley and power steering pump assy should be gloss black
Steering wheel center cap looks awfully dark ( maybe a 68 cap ? ) Shifter knob is chrome - should be woodgrain ( maybe an early car thing ?)
[Re: blewbyu]
#1216644
04/16/12 05:41 PM
04/16/12 05:41 PM
Posts: 426 Mid-Atlantic
Scatransit
Mid-Atlantic
Shouldn't the engine be turquoise with A/C?
[oo]======[oo]
[Re: Scatransit]
#1216645
04/16/12 05:57 PM
04/16/12 05:57 PM
A12
N.E. OHIO, USA
I thought 440 HP were orange regardless of A/C or not???? Thought that was a 383 HP thing???
[Re: A12]
#1216646
04/16/12 07:06 PM
04/16/12 07:06 PM
Posts: 75,087 A Banana Republic near you.
JohnRR
383 thing , a turquoise 440 in 69 would be the 350HP version .
[Re: RUNCHARGER]
#1216648
04/16/12 10:31 PM
04/16/12 10:31 PM
A12
N.E. OHIO, USA
Nice looking car. A few wrong finishes and minor details, that wouldn't stop me from buying it.
Sheldon
and with A/C in Florida it's a no brainer IMO
[Re: A12]
#1216649
04/16/12 11:26 PM
04/16/12 11:26 PM
Posts: 5,123 Warrenton, VA
RoadRunnerJD
Warrenton, VA
The GTX was only available with the 375 HP 440 or a Hemi
[Re: blewbyu]
#1216650
04/18/12 12:22 AM
04/18/12 12:22 AM
Posts: 4,700 North Central USA (MN-WI area)
MuscleMopars
I am looking at purchasing this 69 GTX and i would have thought that a GTX would have a 3speed wiper motor being it was a high end package car. Is it possible that it came with a 2 speed wiper motor? Here is a picture of the engine bay what do you think about the picture, does everything look correct? It looks like a 2 speed motor.
What's wrong with it?
It's not in your garage. Or is it?
Thanks, Eric email eric@musclemopars.com 715-426-HEMI (Shop) 612-669-CARS (Cell and Texts)Go to my Moparts "Profile" to see my web site
[Re: drmopar]
#1216651
04/18/12 12:35 AM
04/18/12 12:35 AM
Posts: 4,998 North Pole,New York
formula_s
North Pole,New York
A bodies prior to 70 also had non-power discs. I had a 68 383 with non-power discs.
[Re: MuscleMopars]
#1216652
04/18/12 09:29 PM
04/18/12 09:29 PM
Posts: 4,284 Florida
blewbyu
You obvious know me pretty well Eric, Right now its priced alittle on the high side or it would be parked next to my A4 A12 Superbee as I'm typing
[Re: gtx6970]
#1216653
04/18/12 10:15 PM
04/18/12 10:15 PM
Posts: 4,150 lewiston, ID
cornucopia
lewiston, ID
friend of mine has a EARLY August'68 build charger and it has the chrome knob on the stick, and also 1968 doors! the factory drilled new holes for the lock knobs, but the old(1968) one are there also. it's got lots of carry-over, 1968 parts on it. pretty cool to look it over!
