Re: Another 1963 Max Wedge Savoy project
[Re: Anselmi]
#1215183
04/13/12 04:26 PM
04/13/12 04:26 PM
Posts: 243 Helsinki, Finland
Anselmi
Helsinki, Finland
Cowl patched with part cut from donor car.
'66 Plymouth '64 Dodge '63 Plymouth x 3
[Re: Anselmi]
#1215185
04/13/12 04:34 PM
04/13/12 04:34 PM
Anselmi
Helsinki, Finland
Donor 2d HT Fury and 2d sedan Savoy side by side.
[Re: Anselmi]
#1215186
04/13/12 04:39 PM
04/13/12 04:39 PM
Anselmi
Helsinki, Finland
Bumper brackets moved from the donor car.
[Re: Anselmi]
#1215187
04/13/12 05:19 PM
04/13/12 05:19 PM
Anselmi
Helsinki, Finland
Even though the extra piece of metal in the previous picture (and the lack of edge) is hardly visible after upper control arms are in place, corrections were made.
[Re: Anselmi]
#1215188
04/13/12 05:27 PM
04/13/12 05:27 PM
Anselmi
Helsinki, Finland
Engine room starts to look like it should.
[Re: Anselmi]
#1215189
04/13/12 05:32 PM
04/13/12 05:32 PM
Anselmi
Helsinki, Finland
Another angle. Notice the missing part of passenger side inner fender where the hood hinge should be bolted.
[Re: Anselmi]
#1215191
04/13/12 05:59 PM
04/13/12 05:59 PM
Anselmi
Helsinki, Finland
Torsion bar rear mounts had been removed to save weight, I guess. They were not needed in a straight axle setup, but now they need to be welded back.
[Re: Anselmi]
#1215192
04/13/12 06:02 PM
04/13/12 06:02 PM
Anselmi
Helsinki, Finland
Driver side mount removed from the donor car and welded in place.
[Re: Anselmi]
#1215193
04/13/12 06:05 PM
04/13/12 06:05 PM
Anselmi
Helsinki, Finland
Same operation for the passenger side.
[Re: Anselmi]
#1215194
04/13/12 06:09 PM
04/13/12 06:09 PM
Anselmi
Helsinki, Finland
Transmission/torsion bar crossmember ready to rock and roll. Notice the crude torched opening for the manual hump.
[Re: Anselmi]
#1215195
04/13/12 06:26 PM
04/13/12 06:26 PM
Anselmi
Helsinki, Finland
Next was the trunk floor. It's hard to see from this pic, but there was few dozen extra holes, and a missing spare wheel bracket. No serious rust anywhere. You can also see the modifications made for outer wheel wells for the flares.
[Re: Anselmi]
#1215197
04/13/12 06:35 PM
04/13/12 06:35 PM
Anselmi
Helsinki, Finland
Antenna hole on rear fender welded shut. No radio in this car.
[Re: Anselmi]
#1215198
04/13/12 06:39 PM
04/13/12 06:39 PM
Anselmi
Helsinki, Finland
Manual hump had been mutilated with a hole on the side for adjusting shifter rods and enlarged top opening for what ever reason.
[Re: Anselmi]
#1215199
04/13/12 06:41 PM
04/13/12 06:41 PM
Anselmi
Helsinki, Finland
And the hump after Oskari did some corrective actions.
[Re: Anselmi]
#1215200
04/13/12 06:46 PM
04/13/12 06:46 PM
Anselmi
Helsinki, Finland
Next part will be the rear wheel openings and outer wheel well. The flares will be gone forever, nothing to save, mostly thick layers of bondo. Here is a small cut to see what it's made of.
[Re: Anselmi]
#1215201
04/13/12 06:50 PM
04/13/12 06:50 PM
Anselmi
Helsinki, Finland
And this is where we are now. I hope I didn't do a major screw-up assuming that 1964 Dodge will have identical wheel openings as a 1963 Plymouth. I know the rear fender is more different the further back you go, but hopefully I can use these. If not, they did a long journey from California to Finland for nothing...
