Re: 512 Low Deck Dyno Results
[Re: moderncylinder]
#1214401
07/10/12 05:11 PM
07/10/12 05:11 PM
Posts: 632 Casco, MI
Savoy1964
Casco, MI
A lot depends on which calculator you use 715 to 796 is the range of answers you can get from them. Still an hour before I get home and can see what day the run was made on.
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph 2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
[Re: moparniac]
#1214403
07/10/12 06:31 PM
07/10/12 06:31 PM
Savoy1964
Casco, MI
Density Altitude: 1855 feet above sea level
Stock and Mildly Modified Naturally Aspirated Engines 9.551 @ 141.557 MPH
Extensively Modified Naturally Aspirated Engines 9.634 @ 140.44 MPH
Time Temperature Humidity Pressure 8:53 AM 78.1 F 45 % 29.98 in
[Re: Savoy1964]
#1214404
07/10/12 07:09 PM
07/10/12 07:09 PM
Posts: 243 NJ
arc
NJ
I come up with 725hp from the et 690 from mph this is y we shouldn't get crazy over dyno numbers.
[Re: arc]
#1214405
07/10/12 07:38 PM
07/10/12 07:38 PM
Posts: 6,295 U.S.
moparniac
U.S.
everyone uses a calc one way or another...who knows which one is to say which is correct over the other just like dynos... it's all about the ET to me anyways....
Mopar Performance
[Re: moparniac]
#1214406
07/10/12 09:26 PM
07/10/12 09:26 PM
Posts: 2,530 PA
moparacer
PA
I am currently running my car at 3200lbs and at 3000ft DA this past weekend in horrible air it went 9.45 @ 141
Never dynoed it but its right around 750 hp best I can figure.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: Savoy1964]
#1214407
07/10/12 11:20 PM
07/10/12 11:20 PM
Posts: 16,934 NC
440Jim
NC
Density Altitude: 1855 feet above sea level Time Temperature Humidity Pressure 8:53 AM 78.1 F 45 % 29.98 in
Your car is running good. And should do a little better if you lean it out. The lack of sixty foot performance is holding it back. I don't know if it is converter, 1st gear ratio, or what.
Like I said, IMO your engine is making about the same as mine, and I am happy.
[Re: gregsdart]
#1214409
07/11/12 09:24 AM
07/11/12 09:24 AM
Savoy1964
Casco, MI
Thanks for the comments I am happy with the performance. Running on SS springs (02-03) is most likely a limiting factor in 60ft and I don't want to go any bigger on tires 29.5 10.5W, bigger means tubbing.
Its an early 60's pushbutton trans and I am not sure what the first gear is.
[Re: Savoy1964]
#1214410
07/11/12 09:29 AM
07/11/12 09:29 AM
Posts: 10,038 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Pretty sure it is 2.45 low. Never heard of a different ratio for a BB 727. Good luck with the suspension, I am betting you can make it work better. The tires ought to be sufficient based of 440JIMS, performance.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
[Re: gregsdart]
#1214411
07/11/12 09:35 AM
07/11/12 09:35 AM
Savoy1964
Casco, MI
Just did a little research and 2.45 is the first gear. I just need to do a little more testing I will be at Milan this weekend have to play with jetting and see what I get.
[Re: Savoy1964]
#1214412
07/11/12 10:02 AM
07/11/12 10:02 AM
Posts: 3,300 Northern Indiana
Dunnuck Racing
Northern Indiana
Just throwing this out there,you may want to check into how much convertor slip you have on the top end I did not see anything posted about your rpm crossing the line or any information about your convertor. Another thing that might affect your performance is the difference between your ignition and fuel system,and the systems used on the dyno. Keith
[Re: Dunnuck Racing]
#1214413
07/11/12 11:09 PM
07/11/12 11:09 PM
Savoy1964
Casco, MI
I have found it hard to tell the exact rpm through the traps but the shift light will usually com on just as I go through the finish so approximately 7200-7300
