Re: 512 Low Deck Dyno Results
[Re: moderncylinder]
#1214381
04/16/12 01:58 PM
04/16/12 01:58 PM
Posts: 31,112 Oregon
AndyF
thats alot of power to make with that head,, with no vac pump, and std fuel, non-oxygenated.... also thats alot of fuel,, like 375lbs/hr to get through the intake system at 7100rpm,,, good job guys
Yep, it is making good power. I'd like to do a side by side test with my 514 just to see how it stacks up.
[Re: AndyF]
#1214382
04/17/12 10:48 PM
04/17/12 10:48 PM
Posts: 399 SouthEast Michigan
PETE@BESTMACHINE
SouthEast Michigan
Andy that sounds great, What parts are the same between the two engines, the crankshaft stroke?
[Re: Al_Alguire]
#1214385
04/23/12 09:54 AM
04/23/12 09:54 AM
Posts: 632 Casco, MI
Savoy1964
Casco, MI
Motor is installed and running, I will not be able to test run it for a couple of weeks, it might just have to go to Columbus in May for its first runs.
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph 2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
[Re: moparniac]
#1214389
07/09/12 02:57 PM
07/09/12 02:57 PM
Savoy1964
Casco, MI
Car weighs 3450 with me in it so subtract 240 and 3210 would be it.
Its the 64 I was at the Louisiana Monster Mopar weekend, car ran great but driver needs more practice.
[Re: Jwilli500]
#1214391
07/09/12 03:50 PM
07/09/12 03:50 PM
Savoy1964
Casco, MI
I'll get that posted when I get home all the data is there I can't rember off hand.
Callies billet I-Beam rods
[Re: moparniac]
#1214394
07/09/12 10:18 PM
07/09/12 10:18 PM
Savoy1964
Casco, MI
1.39 60ft 4.01 6.21 @ 111.11 8th mile 8.13 1000ft 9.75 @ 138.50
[Re: Jwilli500]
#1214396
07/10/12 03:54 PM
07/10/12 03:54 PM
Savoy1964
Casco, MI
No problem any other info i can give just ask.
I did not play with jetting on the 9.75 run I would expect I could of gone faster the jetting is fat at the moment.
[Re: Savoy1964]
#1214397
07/10/12 04:09 PM
07/10/12 04:09 PM
Posts: 16,934 NC
440Jim
NC
3450 lbs with driver
Does anyone have the weather like for that run? (June 8-10, Gateway, time) Heat, humidity, elevation 400ft?(atm pressure) all play a role. Track Weather History - DRR
875 hp at 7100, 713 ft-lb at 6000 at standard day (60F, 29.92"Hg)
I am trying to compare my 511 at 3250 lbs 9.38 at 140 mph, 73F, 30.01"Hg (80 ft track elevation helps). I bet the corrections would make it close, assuming hotter/higher at MM.
[Re: 440Jim]
#1214398
07/10/12 04:23 PM
07/10/12 04:23 PM
Savoy1964
Casco, MI
I will look up date and time and get the corrected time and speed. http://www.dragtimes.com/da-density-alti...et+Weather+Data
