Re: Edelbrock carb & kickdown throttle cable ant right???
[Re: hooziewhatsit]
#1214308
04/18/12 12:43 AM
04/18/12 12:43 AM
Posts: 497 Partridge, KY
Hoop
Partridge, KY
Yep, you'll want to get the correct edelbrock adapter.
And, the slot in the kickdown MUST be held against the throttle studs at all times (by that long spring). If you have a gap there right now, that's your problem.
When you push the throttle open, the lever must move immediately with it. The long slot is so if the kickdown linkage binds up, the throttle can still close (before things get exciting ).
When I did my 4bbl conversion I had to extend the linkage about an inch so I had enough adjustment to keep it against the throttle stud.
yep, mine douse have a pinkey gap!
[Re: Hoop]
#1214310
04/18/12 01:08 AM
04/18/12 01:08 AM
Posts: 75,092 A Banana Republic near you.
JohnRR
Ok, I know what I haft to do to get the rod right, now I just got to finger out wear to put the throttle cable at when I get the adapter bracket on!
On the stock stud that you install on the adaptor bracket that you need to connect the trans linkage ... this isn't rocket science .
[Re: Hoop]
#1214312
04/18/12 07:43 AM
04/18/12 07:43 AM
Challenger 1
Cincinnati, Ohio
ok, if thats wear the throttle cable post to go, then I may not have a stock stud, I may haft to get a smaller stud for it, because it well not fit on thear!
[Re: Challenger 1]
#1214313
04/22/12 11:07 AM
04/22/12 11:07 AM
JohnRR
x2 ....
[Re: bboogieart]
#1214314
04/28/12 12:51 AM
04/28/12 12:51 AM
Hoop
Partridge, KY
This makes it sooo much easier
Hmmm That looks like a G.M. throttle valve cable to me.
My 4 bbl. is a Holley but I just added a curved slotted bar from a /6 and it works great.
it could be gm, I don't think the throttle cable is the stock one, it seems too long to me! I did get time to change it around today, but it, drives smooth, but steel likes some getting full throttle & I am goin haft to adjust some more on the kickdown to get the passing gear to work!
Also the throttle cable would not go on the stud because it had a nut in it that I had to take out to put it on the stud!
