Page 2 of 5 1 2 3 4 5
Re: what's wrong... [Re: Mr.Yuck] #1211824
04/08/12 12:04 AM
04/08/12 12:04 AM
MR_P_BODY Offline
MR_P_BODY  Offline
vern it roll at least 5-10' after clearing. They don't give us much room that's for sure. Usually I just take it up to about 3k hold or a second and move forward...seemd like it wanted to stall so I gunned it more than usual.
Still have the factory amp gauge hooked up, looks good.
Voltage at your amp gauge doesnt mean anything...
check it at the pump and also at the ignition...
is that old fuel in your tank... it sounds like its
old fuel or it has water in it... could just be the
ignition
Re: what's wrong... [Re: Mr.Yuck] #1211825
04/08/12 01:17 AM
04/08/12 01:17 AM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
check the cap & rotor. just found a bad msd cap on a friends car.
Re: what's wrong... [Re: Mr.Yuck] #1211826
04/08/12 02:04 AM
04/08/12 02:04 AM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
I had almost exactly the same problems with mine.
I had a brand new set of valve springs turn into junk almost from the start. I kept overlooking them because they were new. I replaced pretty much everything in the fuel system and the ignition twice until I finally pulled them off to check them. They were complete junk. I was in a hurry to get to an event so I put the old set of springs I pulled out back on. FIXED!!!
Don't overlook the valve springs just because they are new.
Re: what's wrong... [Re: rook440] #1211827
04/08/12 03:10 AM
04/08/12 03:10 AM
wine country
8
8urvette Offline
8urvette  Offline
wine country
Check your grounds too to make sure they are clean and now corosion ,,,a good ground is very important and is often over looked ...
I had a buddy with a low 12 sec nova, ran great, all of sudden about 5000 rpms it would start to cut out.
he changed alternators, distributors, fuel pumps, battery, plugs, wires... he was about ready to give up when we discovered the grounds were solid and tight, but had built up corrosion between them and the chassis. we couldn't see it by looking at them, but just on a whim we pulled one and discovered this.
cleaned them all, and added a few more and problem was gone.
Re: what's wrong... [Re: Mr.Yuck] #1211828
04/08/12 06:04 AM
04/08/12 06:04 AM
Tampa Florida
dc426 Offline
gotta keep'm separated
dc426  Offline
Tampa Florida
do you have some kinda water injection or something on that car?
Re: what's wrong... [Re: dc426] #1211829
04/08/12 07:47 AM
04/08/12 07:47 AM
DC, MD Suburbs
440PURSUIT Offline
440PURSUIT  Offline
DC, MD Suburbs
Didn't you change the Ignition box before the last run? That was heading in the right direction since you went 7/10's better.
I've had some probs grounding Mopar Boxes before.
My Belvy convert Valve Springs were bad. When they floated the car would load up and break down.
Was one soft intake. Changed the springs and all was good. Did it seem flooded after run?
Re: what's wrong... [Re: 440PURSUIT] #1211830
04/08/12 09:13 AM
04/08/12 09:13 AM
A57_RT Offline
Parts Problem
A57_RT  Offline
Parts Problem
My $$ is on the ign box, had a friend with the car to beat on pinks watch 10k go due to the same sounding high rpm miss in high gear...MSD box.
Re: what's wrong... [Re: A57_RT ] #1211831
04/08/12 09:47 AM
04/08/12 09:47 AM
Lost in Pooler, GA
Gumbydammit Offline
Gumbydammit  Offline
Lost in Pooler, GA
The Valve springs were not new when you bought the motor from me. I re ringed it, new bearings, put a 'street' roller cam in it, New timing chain, etc. and such just like we discussed. basically, A freshened bracket motor with a new cam.
I'd test the valve spring pressure just to be sure. It's been so long, I don't remember if they were new with the previous roller cam or not. With a Solid roller cam, and street driving, it's a good idea to check the springs once in a while anyway.
I wouldn't get carried away with worrying about the open or closed pressures when using an on-head tester, but rather seeing if there are big differences between the springs, and if one seems to get weaker faster than the others.
Anyway, that being said, I'd take the advice of others too, fuel pressure, and maybe try a pass on a mix of race gas and not Meth inj.
I'm Gumby dammit!
Re: what's wrong... [Re: A57_RT ] #1211832
04/08/12 10:33 AM
04/08/12 10:33 AM
Indianapolis, In. area
BTBelvedere Offline
BTBelvedere  Offline
Don't overlook something real simple, like a plug wire boot that melted on a header. Wait until it gets dark, get a helper, and put it on the brake with the hood open. You might be surprised what you see.
Re: what's wrong... [Re: Gumbydammit] #1211833
04/08/12 10:44 AM
04/08/12 10:44 AM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
Thanks guys, Sorry Gumby thought they were newer.. I'll hit the other items real quick and see how it goes, Chirs K. I went better the last pass because i stayed in it the 2nd pass I let out of it as soon as I hit 3rd. and don't hate on my green helmet...hahaha. It didn't seem to run bad at all at the end of the track, plugs looked good too..maybe a tad lean. I'll give it a once over and get the MSD in.
What's the best way to test the springs? I also fiund another problem as I went to get a beer last night, seems the Drivers side axle seal has quit...that will be 1st on the list. and the traction bars are gone, went from 1.60 to 1.68 even a 1.86 sixty foot (last pass)
Chris D.. yes I have the winshield washer injection, I thought that was it too, I cut it off on the 2nd pass when t started breaking up and it kept on doing it.
BTBel..I checked them at the track, but I'll do a re-look here, nice and cool now.
Anyway had fun, at least nothing broke. And I had 3 people tell me I had the coolest car at the track.. I said don't look to colse you might change your mond.
Re: what's wrong... [Re: Mr.Yuck] #1211834
04/08/12 11:06 AM
04/08/12 11:06 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
My money says valve springs. B.T.D.T.
Re: what's wrong... [Re: tubtar] #1211835
04/08/12 11:21 AM
04/08/12 11:21 AM
Amherst,NY
challengermike Offline
Amherst,NY
Im guessing valve springs. if you listen to the vid it starts to break up mid rpm in 2nd gear. I have had an msd box do the same thing to me also though.
Re: what's wrong... [Re: challengermike] #1211836
04/08/12 11:34 AM
04/08/12 11:34 AM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
I'll start cheapest to most expensive...lol
fuel pressure up, clean all the grounds, check wires, check cap-rotor, Install the MSD go for a blast. If it still falls apart, I'll check the springs.
The gas SHOULD be good. I added stablizer last year, and have driven it a lot over the winter. It had 10 gallons of new 93 in it...Unless that gas was older (sitting in the ground for a while).
Re: what's wrong... [Re: Mr.Yuck] #1211837
04/08/12 11:48 AM
04/08/12 11:48 AM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Well now with what you know about or do not know about the valve springs. you should get some new ones on it..if it fixs it or not.. That be the first thing I would do..
Re: what's wrong... [Re: Mr.Yuck] #1211838
04/08/12 11:58 AM
04/08/12 11:58 AM
gregsdart Offline
gregsdart  Offline
On the ignition, hard wire it on its' own circuit with all new wire. Solder all connections. Use a separate on off switch. Why? There are gremlins in those old Mopar wiring circuits that can cause problems when a load is placed on them. Sounds to me like resistance in the power circuit to the ignition went up as it got warmer during the run. Or, SOMETHING in the ignition went south as it got heated during the run. Fuel pressure need never be over 7.5 PSI on holley fuel bowls running gas. I have had Tunnelrams show no problems at only 3 psi because that is all it took to pump enough gas through four float bowls to make 650 hp (and keep the bowls reasonably full)on gas. The instant I went to a single dominator, the two bowls needed the extra pressure to keep up. Then 7 psi was needed, and sufficient.
Re: what's wrong... [Re: gregsdart] #1211839
04/08/12 12:14 PM
04/08/12 12:14 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
What size are your fuel lines? You need volume as well as pressure.Also what size is your fuel pressure line going to the gauge? A few years back I had the same problem and like you had plenty of pressure 7lbs all the way down the track with a 1/8" plastic line to the fuel pressure gauge,changed it to a 3/8" line and had only about a 1 1/2 of pressure go through the lights. You also might want to check the size of your needle and seats,the standard size don't cut it for a Big block Mopar.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: what's wrong... [Re: Mr.Yuck] #1211840
04/08/12 12:17 PM
04/08/12 12:17 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Has it ever worked, or it this the first time out?
Re: what's wrong... [Re: dc426] #1211841
04/08/12 01:04 PM
04/08/12 01:04 PM
Az
Crizila Offline
Crizila  Offline
Az
sounds like fuel starvation to me. Nothing in first gear then all through the second half of the track. What kind of fuel pump?
Yep. Fuel issue. Just because you have good pressure doesn't necessarily mean the motor isn't starving for fuel at the big end. Ignition, valve springs,etc, would most likely show up in every gear.
Fastest 300
Re: what's wrong... [Re: Crizila] #1211842
04/08/12 01:08 PM
04/08/12 01:08 PM
Tampa Florida
dc426 Offline
dc426  Offline
Tampa Florida
Plus the fact you're running a 6 pack. i forgot about that. FUEL!
Re: what's wrong... [Re: Crizila] #1211843
04/08/12 01:12 PM
04/08/12 01:12 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I thought so too.......I sent the box to Tx. ( MSD 7 AL )and it checked good.
Swapped chips for r.p.m. with ones that I knew worked.
I was pulling plugs and showing them to guys I trusted , checked connections , set and re-set floats and regulators , did the volume test etc.
But when the motor was pulling hard in 2nd and 3rd , it sounded just like it was on the chip.
It was a valve spring.
1st revved out just fine , so it didn't make sense to me either , but that cured it.
