Disc o Tech red flag! Why does it do this? #1211540
04/07/12 10:45 AM
04/07/12 10:45 AM
Mid Michigan
Coronet-R/T-Rag Offline OP
Mid Michigan
Just completed a front disc brake swap on my 67 b body. Went from power drums to manual discs. 15/16 master cylinder. Wilwood / mp adjustable proportioning valve. It's all bleed and everything works great! Except - The back brakes lock up first no matter what i do! What am I doing wrong? I guess I'm wondering if my factory proportioning valve is sticking? I thought the drum / drum valve was more like a splitter that a proportioning valve? Help.
Re: Disc o Tech red flag! Why does it do this? [Re: Coronet-R/T-Rag] #1211541
04/07/12 12:27 PM
04/07/12 12:27 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Do the rear drum adjusters need to be backed off? Someone correct me if I'm wrong.
Mo' Farts
Moderated by "tbagger".
Re: Disc o Tech red flag! Why does it do this? [Re: Grizzly] #1211542
04/07/12 12:35 PM
04/07/12 12:35 PM
Washington State
70_FY1_N96_BEEP Offline
Washington State
Sticking parking brake? What wheel cylinders you have back there?
Rock Auto/Raybestos Wheel Cylinders WC37236
will help the biasing.
Re: Disc o Tech red flag! Why does it do this? [Re: 70_FY1_N96_BEEP] #1211543
04/07/12 12:58 PM
04/07/12 12:58 PM
Mid Michigan
Mid Michigan
Parking brake works freely. Wheel cylinders are stock / unchanged. I thought I could adjust the bias with the wilwood proportioning valve but not so much.
Re: Disc o Tech red flag! Why does it do this? [Re: Grizzly] #1211544
04/07/12 01:07 PM
04/07/12 01:07 PM
Mid Michigan
Mid Michigan
I was wondering about that. I did adjust them tight then back them off till there was no drag. Backing them off farther might help but does that fix the problem?
Re: Disc o Tech red flag! Why does it do this? [Re: Coronet-R/T-Rag] #1211545
04/07/12 01:52 PM
04/07/12 01:52 PM
Eugene, Oregon
Secret Chimp Offline
Eugene, Oregon
No, it shouldn't. You refer to an adjustable valve and then wonder about your factory valve, which one are you using? Why haven't you just adjusted the bias forwards (maybe you put it on backwards?)
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
Re: Disc o Tech red flag! Why does it do this? [Re: Secret Chimp] #1211546
04/07/12 02:02 PM
04/07/12 02:02 PM
Mid Michigan
Mid Michigan
I used the Mopar Action / Disc o Tech as a guideline and it said to leave the factory proportioning valve in place and just add an adjustable valve in the rear line to control bias. So I am running both valves. The Wilwood valve is marked in / out and is installed correctly. I have rotated the knob all the way in both directions and when it is "closed" I have mostly back brakes. When it is "open" I have better front brakes but the backs still lock first. It is close though.
Re: Disc o Tech red flag! Why does it do this? [Re: Coronet-R/T-Rag] #1211547
04/07/12 02:07 PM
04/07/12 02:07 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Drum brake cars use a simple, distribution block.
Technically, you should be running a disc/drum combination valve.
You could also try the 7/8" bore wheel cylinders mentioned earlier to decrease the rear line pressure.
Re: Disc o Tech red flag! Why does it do this? [Re: DoctorDiff] #1211548
04/07/12 02:20 PM
04/07/12 02:20 PM
Washington State
Washington State
Yup, big difference in the two. I did my '67 Coronet 500 and it was stunning for manual brakes. Brakes are nothing to mess with, I cringe when posts suggest using the distribution block instead of the combination valve which sets the initial BIAS for disc/drum, the Wilwood valve is used for fine tuning and is needed. Combination valves are not all the same either. Vehicle weight comes into play.
Re: Disc o Tech red flag! Why does it do this? [Re: Coronet-R/T-Rag] #1211549
04/07/12 02:27 PM
04/07/12 02:27 PM
WA
P
pro451bee Offline
pro451bee  Offline
P
WA
Maybe the rear shoes are contaminated with oil ? You got master routed corectly and dont have circuits reversed?Rear port should go to front brakes .
Re: Disc o Tech red flag! Why does it do this? [Re: 70_FY1_N96_BEEP] #1211550
04/07/12 02:32 PM
04/07/12 02:32 PM
WA
P
pro451bee Offline
pro451bee  Offline
P
WA
New cars have no combo valve anymore ,just well balanced /engineered piston /rotor sizes teemed with ABS that only kicks in on slick surfaces.
Re: Disc o Tech red flag! Why does it do this? [Re: Coronet-R/T-Rag] #1211551
04/07/12 02:58 PM
04/07/12 02:58 PM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
I NEVER WROTE THAT. if you are using an adjustable valve, which is what I always recommend, THERE SHOULD BE NO OTHER VALVE. Just leave the OEM drum-car distribution block and splice in the adjustable valve downstream from there.
Rick E.
Re: Disc o Tech red flag! Why does it do this? [Re: Rick_Ehrenberg] #1211552
04/07/12 03:02 PM
04/07/12 03:02 PM
Marlboro, NY, USA
Marlboro, NY, USA
Incidentally, using the 11.75" rotors typically improved proportioning a bunch.
Getting the "native" proportioning as close as possible (by juggling caliper and rear wheel cyl bores) and then using the adj. valve will improve light-pressure stops (rain, etc.) a whole bunch -- the valve doesn't kick in until a few hundred PSI.
Rick
Re: Disc o Tech red flag! Why does it do this? [Re: Coronet-R/T-Rag] #1211553
04/07/12 03:05 PM
04/07/12 03:05 PM
WA
P
pro451bee Offline
pro451bee  Offline
P
WA
More rubber on back will help too .
Re: Disc o Tech red flag! Why does it do this? [Re: Rick_Ehrenberg] #1211554
04/07/12 04:15 PM
04/07/12 04:15 PM
Mid Michigan
Mid Michigan
Rick E.
Sorry Rick, I mixed up proportioning valve with Distribution block. I am running the OEM drum-car distribution block with the adjustable valve downstream. No other valve.
Re: Disc o Tech red flag! Why does it do this? [Re: Rick_Ehrenberg] #1211555
04/07/12 04:19 PM
04/07/12 04:19 PM
Mid Michigan
Mid Michigan
Rick
I am running the 11.75 rotors with Cordoba caliper brackets. I will change up the rear cyl bore size and see if that helps.
Re: Disc o Tech red flag! Why does it do this? [Re: pro451bee] #1211556
04/07/12 04:22 PM
04/07/12 04:22 PM
Mid Michigan
Mid Michigan
Oil makes the shoes "grabby"? I'll double check. I do have the master cylinder circuits correct.
Re: Disc o Tech red flag! Why does it do this? [Re: Coronet-R/T-Rag] #1211557
04/07/12 04:54 PM
04/07/12 04:54 PM
AndyF Offline
AndyF  Offline
How hard are you braking when the rears lock up? The brakes shouldn't lock up unless you're really standing on them. If they are locking up under normal braking force then you have different problem. The brakes could be put together wrong, or be contaminated, or the drums are machined wrong, something like that.
If the rears are locking up before the fronts during a full on panic stop then you have a bias issue.
(I covered this topic in more detail in my B-body book.)
Re: Disc o Tech red flag! Why does it do this? [Re: AndyF] #1211558
04/07/12 05:04 PM
04/07/12 05:04 PM
Mid Michigan
Mid Michigan
I've read your new book, it's very good. So good in fact that a friend has already "borrowed" it. The backs are locking first under a maximum "panic" stop. Under normal driving the brakes work great. Much better than before. I took advice from your new book and got the stainless brake hoses from Dr. Diff for my rear mounted calipers. They are a perfect fit and I would suggest them to anyone doing a swap.
Re: Disc o Tech red flag! Why does it do this? [Re: Coronet-R/T-Rag] #1211559
04/07/12 05:34 PM
04/07/12 05:34 PM
Forth Worth, Texas, USA
TheRamMan Offline
TheRamMan  Offline
THE( THOSE ) VALVES DONT ALWAYS CUT THE LINE PRESSURE BY .3333
MAYBE JUST .25
I SEE THIS CONSTANTLY, VALVE VARIATION,AND TIRE TYPE AFFECT FINAL BIAS,NO REAR SKID CONDITION...OFTEN UN OBTAINABLE .....WITH 60s
TECHNOLOGY..............WAYNE TRM
