Re: Disc o Tech red flag! Why does it do this? [Re: Coronet-R/T-Rag] #1211560
04/07/12 07:08 PM
04/07/12 07:08 PM
AndyF Offline
AndyF  Offline
If the rears are locking up first under panic stop conditions then you either need more front brake bias, or less rear.
To get more front bias you can go with higher friction pads, go to larger rotors, use calipers with larger pistons, etc. (I assume you have 11.75 rotors with 2.75 inch calipers? If not, that would be the first thing to change.)
The reverse works for the rear. Smaller wheel cylinders, smaller drums, etc.
Weight distribution and ride height also play a part but those things are a little harder to adjust.
Re: Disc o Tech red flag! Why does it do this? [Re: pro451bee] #1211561
04/07/12 09:58 PM
04/07/12 09:58 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
"New cars have no combo valve anymore, just well balanced /engineered piston /rotor sizes teemed with ABS that only kicks in on slick surfaces."
You are talking about 4 wheel disc brakes.
The OP has a disc/drum system.
I'm not a brake expert, but as far as I know, discs and drums don't react the same, so a combination valve (with a hold-off function) is beneficial.
Re: Disc o Tech red flag! Why does it do this? [Re: Coronet-R/T-Rag] #1211562
04/08/12 01:23 PM
04/08/12 01:23 PM
iowa
copchaser Offline
copchaser  Offline
iowa
did you replace your rear shoes? Do you have them installed corretly? I know for a fact that if you have the leading and trailing shoes backwards the rear brakes will lock. Thats why I don't drink when doing brakes, lol.
Re: Disc o Tech red flag! Why does it do this? [Re: copchaser] #1211563
04/08/12 10:10 PM
04/08/12 10:10 PM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
Good point. That would markedly increase the self-energizing action.
Rick
Re: Disc o Tech red flag! Why does it do this? [Re: Rick_Ehrenberg] #1211564
04/09/12 01:00 PM
04/09/12 01:00 PM
NJ
rth Offline
rth  Offline
NJ
make certain that park brake lever on shoe is fully retracted and not being held by faulty cables.
