Re: Best value / most effective balancers?
[Re: polyspheric]
#1208976
04/04/12 11:02 PM
04/04/12 11:02 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Wright radial engine: steel case (block) planatary nose gear box in the front and a centrifrugal supercharger on the back: no damper Pratt & Whitney: Aluminum case, planatary nose gear box in the front and a centrifrugal supercharger on the back: no damper Allison: Aluminum 60* V12 Spur gear drive, single overhead cam, roller rockers, 2 plugs per cylinder, it came with or without turbocharger, some came with centrifrugal blower and no damper. Rolls Royce Merlin and Griffon: same configuration as the allison Quote:
WW2 aircraft engines: 1. radial, low RPM (B29, P47) 2. V12 in-line, low RPM (P51 with Rolls engine: 6" stroke) and has inherent primary balance (same as in-line 6)
[Re: polyspheric]
#1208977
04/05/12 06:29 AM
04/05/12 06:29 AM
Posts: 2,709 NJ central
Scamp408
NJ central
Thats what I was told a german design given to japan for the fighter planes. He could be wrong but half the people on some of the web forums are. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: Fluidampr1]
#1208980
04/07/12 12:11 AM
04/07/12 12:11 AM
Posts: 12,419 Taxes & Virus's R-US, NY
Dragula
Hi Guys,
My name is Ivan and I work for Fluidampr. I am not here to push product but to provide facts about Fluidampr dampers and answer any questions you have.
Fluidampr products use a unique viscous design that we invented in 1946 for diesel applications. In the mid 80's we developed dampers for gas racing engines and street rods.
Most dampers use an elastomeric design, basically rubber bonded between sections of steel. This essentially is a tuned absorber and will only do its job effectively at a pre-determined narrow bandwidth. Fluidampr's viscous design incorporates an internal inertia ring shearing through a thin layer of viscous silicone. Viscous silicone is 45,000 times thicker than a 30w motor oil and is very thermally stable and will not break down like rubber. A dampers job is to absorb torsional vibrations (harmonics) and take that energy turning it to heat and dissapating out the damper faces. With elastomeric dampers the rubber will eventually break down and if not repaired will cause the damper to seperate and worse case grenading in the front of the engine. With Fluidampr's design this cannot happen and as long as you do not lose the press fit on the bore, the Fluidampr will last for the life of the engine. The other big advantage of a Fluidampr is that it is able to combat harmonics at all RPM's vs. the pre-determined bandwidth found with elastomeric dampers. Almost all heavy duty diesel engines use viscous dampers. We are OEM suppliers to many of these companies. The only reason car and light duty manufacturers do not use viscous dampers is from a cost standpoint. There a couple of high end OEM gas engines now using viscous dampers such as Ford GT40, Audi R8, Lamborghini Gallardo.
Please let me know if you have any questions about dampers, torsional vibrations, or Fluidampr product and I will be happy to answer.
If its so efficient, why does it have to weigh more than the stock damper? Doesn't seem right to me.
And I can't remember on my diesel, if it was a fluid type, but it let go after 280k and took out my serp belt and a few other things under the hood. Tried to get another, and you guys wanted 10 days for a new one...Couldn't be without the truck that long.
And why do we use viscous couplings in AWD vehicles....Because when a wheel slips and transmits that slippage to the transfer box, it heats up the silicon fluid, and it expands and locks in the other wheels in the drive line...Can't say its thermally inert when we use them everyday in AWD vehicles to do just the opposite, sorry.
[Re: Dragula]
#1208981
04/07/12 02:31 AM
04/07/12 02:31 AM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
Hi Guys,
It is not the heat that makes a viscous coupling "engage" upon slipage, it is because the friction of trying to bend the mass of fluid rapidly. If you put your finger in a big bowl of the stuff you can move your finger through it easily but try to stir it real fast with your finger and it is very hard, nearly impossible to stir fast and the faster you try to stir it the harder it is to stir at all. I tried it with cold fluid (about 40*F) and warm fluid (about 120*F) and it feels the same so I doubt the temp change has a significan effect on the coupling, if it was significant it would not work good in a fluid coupling because it would be too tight when cold and too loose when hot or vise versa.
[Re: HotRodDave]
#1208983
04/09/12 03:29 AM
04/09/12 03:29 AM
Posts: 6,150 Melbourne , Australia
LA360
I am putting a Powerbond onto my street 360 (it should still make 450-470hp) purely because the price was right. The Pro Street (Cyco Systems) are a great harmonic dampener and I have used a few. I was being a bit of a tight wad with this engine (it's built up out of parts I had lying around), otherwise it would have a Pro Street Balancer on it. If I was building anything racey I would run an ATI, and nothing else! Romac sold the timing set and balancer line to JP Piston in SA when the original owner sold everything up (they were originally QLD based), so long as the quality is still there, the Romac dampener is another option also.
Alan Jones
