Re: best way to store a battery
[Re: mickm]
#1208533
04/02/12 09:06 PM
04/02/12 09:06 PM
RapidRobert
What Challenger said. Might toss it on Craigslist & get some quick cash out of it rather than months later coming back & expecting it to be good. They definitely do go bad
[Re: RapidRobert]
#1208534
04/02/12 09:16 PM
04/02/12 09:16 PM
Posts: 4,179 California
mickm
California
hmmm... not a bad idea. didn't think about that.
thanks for the thought!
[Re: rustbuckett68]
#1208538
04/02/12 11:36 PM
04/02/12 11:36 PM
Posts: 1,168 Vancouver, WA
MoparMarq
Vancouver, WA
From what I have been told, do not store on concrete, block it up on wood.
So, what's the deal with concrete?
[Re: Grizzly]
#1208539
04/02/12 11:36 PM
04/02/12 11:36 PM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
I picked up one of those solar panel/trickle chargers for $20. Fully automatic, won't over-charge.
It sits in a South side window all winter and once a month I rotate the three batteries that I have. The oldest battery has got to be 7 years old now and still works like brand-new.
Dummy-proof and way better than the plug-in 1 amp charger I had.
20 bux well spent.
+1. I have about 6 years old, did a load test on it and passed no problem
[Re: Grizzly]
#1208541
04/03/12 12:05 AM
04/03/12 12:05 AM
mickm
California
20 bux well spent.
that sounds like a good idea. i was thinking it may just be better to sell it, but that sounds encouraging. i have a window i can set up for this, so that should work.
[Re: MoparMarq]
#1208542
04/03/12 12:20 AM
04/03/12 12:20 AM
Posts: 2,966 Wendy, I'm home.
dstryr
Wendy, I'm home.
What I learned from a physics/chemistry teacher way back, two things.
First, when the battery runs over it spills on and makes a mess of the concrete.
Second, the battery is usually grimy & dust covered and often collects condensation being on a cool/cold floor. The slight amount of moisture will allow an extremely small amount of current to flow and discharge the battery. When its dead it is usually in January and the battery will freeze and split open, making the mess from point # one much, much worse.
Valid points? First one yes, 2nd is open for debate.
dstryr, since 1986.
[Re: dstryr]
#1208543
04/03/12 01:45 AM
04/03/12 01:45 AM
Posts: 9,316 SoCal
68HemiB
SoCal
Indeed. The debate includes some who firmly believe the "concrete can drain a [clean] battery" claim to be a wives tale. Even so, some insulating wood sure isn't going to hurt anything...
Down to just a blue car now.
[Re: ahy]
#1208544
04/03/12 01:56 AM
04/03/12 01:56 AM
DaytonaTurbo
Manitoba, Canada
I store them on wood and try to slow charge once a month. As several have posted, it will still deterioriate with time.
The right kind of battery maintainer can help... an inexpensive "trickle charger" that always provides a current weather the battery needs it or not will hurt and may be a safety concern. I've never messed with them for that reason.
The trickle chargers you can buy these days for 20 bucks have an automatic shutoff to stop the current when the battery is full. I don't see any harm in running one of those all the time. My buddy permanently installed one of those in his rv so when he's in there the odd time using the 12v lights or radio he can still keep the battery topped off automatically.
[Re: Grizzly]
#1208546
04/03/12 12:24 PM
04/03/12 12:24 PM
Posts: 445 Fairfield, Ohio
holtzdog55
Fairfield, Ohio
It sits in a South side window all winter and once a month I rotate the three batteries that I have. The oldest battery has got to be 7 years old now and still works like brand-new. Dummy-proof and way better than the plug-in 1 amp charger I had. If you connect all the positives together and all the negatives together...in Parallel....you won't have to keep rotating them....they will all charge at once......
Finally Done....BEERS!!!
[Re: dstryr]
#1208547
04/03/12 01:27 PM
04/03/12 01:27 PM
Posts: 2,825 Sk. Canada
RemCharger
Sk. Canada
Thats the best explination I've heard yet, and is plausible. Batts definately drain through current draw outside of the case. I just fired up my race car yesterday, The batt was unhooked, in the car, since october , And it started and ran like I shut it off an hour ago. No Charger, but 35 degree garage.
[Re: RemCharger]
#1208548
04/03/12 10:39 PM
04/03/12 10:39 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
College Chemistry teacher told me there is no chemical reaction with a battery sitting on the concrete floor ....they usually go dead due to neglect from sitting on concrete floor..
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
