Re: Anyone ever put a 12V Cummins in older Mopar Muscle Car
[Re: DPelletier]
#1208486
04/04/12 11:06 AM
04/04/12 11:06 AM
Posts: 4,086 The Wet Coast, Canada
megajoltman
On a different note, a little over a year ago I dropped a 6BT/727 in my girlfriends `89 2wd 150 Ramcharger. I used 1 ton front coils and cut 1 1/2 rounds off. It sits the right height and rides nice. 23 mpg everyday.
I am thinking about doing almost the same, 85 D100. One thing I am on the wall about, do the 1/2 ton wheel bearings hold up? And how is the front tire wear? What tires are you using? Crossmember changes needed? Not planning any heavy use, trips to the dump, maybe some light towing. A friend bought the perfect donor Saturday, 93 D250 CTD/518, very rusty. $1300, I think I can get a deal. Runs and drives. Thanks
I would use all the suspension, driveline and related components from the D250. The Cummins is over 1100 lbs fully dressed and routinely trashes front end components, ball joints, shocks and tires in my 1 ton trucks. No way I'd run a 5.9 CTD without having load range E tires, either.
1969 Dart 383/727/D60
CTD Ram 4x4 Mega Cab
Procharged 350Z
[Re: 68Bullit]
#1208487
04/04/12 12:53 PM
04/04/12 12:53 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I thought about dropping a 12V in an Imperial for a driver. It definitely has the length. After measuring the CTD in my 92 D250 I can see that I'd need to take 4" out of the oil pan and modify the oil pickup. Stuffing an OD transmission and 2.94 gears out back would have it singing a happy tune. Larger T-bars can be made and the front end already uses light truck components.
A 4BT is a great swap for a lighter car but it needs to be leaned on a bit to run well in a big car.
[Re: Slipknot440]
#1208489
04/05/12 12:34 AM
04/05/12 12:34 AM
Posts: 571 Western NC
68Bullit
Western NC
i've thought about it in the past but just can't justify the cost (right now). I like the sound of a 68 dart, 5.9 CTD, with od and something like a banks system to push it into the 700+hp range and pull over 20 mpg. I've seen a duramax in a 68 impala beat the pants off a Lambo in a 1/4 mile
EXACTLY! I've seen two different chevelle's, both with Duramax setups.... that walked all up AND down both sides of WHATEVER they were racing. I mean, it didn't really matter what they were racing, but for what it's worth, one car appeared to be in the 700'ish hp range, geared, and done up right, but it didn't matter. The smack down was laid before the guy finished racing and then drove his Muscle diesel home to the tune of around 25 mpg. Crazy.
It seems that the Duramax is probably the most feasible setup right now to do this (while being able to make serious power),
I'm gonna stay true to my Mopar faith right now (trying to stay Mopar all the way through), but I still won't lie in saying that I might, just might, consider doing something like a Duramax setup down the road......
[Re: 68Bullit]
#1208490
04/05/12 09:35 AM
04/05/12 09:35 AM
Posts: 12,407 Taxes & Virus's R-US, NY
Dragula
Sad as it is, this may be true. The Cummins makes so much torque at such a low rpm, and does not rev very high, it makes for a difficult engine to drag race with. Whereas the Duracrap has much more in common with a muscle car V8, higher rpm capability, lower inital torque, V8 design, etc...Sucks, but it seems more adaptable than our favorite brand Cummins.
[Re: Dragula]
#1208491
04/05/12 10:57 AM
04/05/12 10:57 AM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
Sort of; the DM IS a better an easier choice to put in a car, but not because of the low RPM/High torque of a Cummins, but because the DM is shorter, lighter and lower. I can't imagine the butchery that would have to be done to a Dart to put a 5.9 Cummins in one! There are many Cummins powered drag vehicles that do quite well and it is certain that it is FAR easier and cheaper to get big power out of a turbo diesel than a gas motor.
...even my daily driver puts out over 400hp and 800 ft lbs and gets almost 20mpg in a 8338 lb dually 4x4. Not bad!
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: DPelletier]
#1208492
04/05/12 01:19 PM
04/05/12 01:19 PM
feets
Senior Management
Senior Management
Irving, TX
The DM is the hot ticket right now for drag racing. They're well ahead of the PS and putting a hurt on the CTD. Where the CTD really shines is in HEAVY work. When the guys are building all-out pulling trucks the CTD is still the engine to beat.
The DM is certainly easier to stuff in a car than a CTD. Just like a 350 is easier to swap than a 440.
I have no interest in a 350 or a DM so I'll stick with a CTD.
[Re: DPelletier]
#1208494
04/15/12 12:04 AM
04/15/12 12:04 AM
Posts: 1,357 central Florida
VL21
central Florida
I get that the cummins is heavier, say 4-500 heavier than a 440 say? I am thinking the front end stuff should hold it with heavier coils. Think coil spring half ton F150 with a snow plow. Sure were a lot of them a few (well more than a few) years back. I understand it is heavy, and in a short bed would be very nose heavy. But think of it, a few mods, 40-50 more hp, 518, maybe 2.9 or 3.2 gears, easy 22-25 mpg and not screaming... Worthless for heavy towing, just a toy...lots of work, and I haven't finished a project rig in years. Another project is just what I need. And my diesel buddy bought still another one today, runs even better than the one he got last week. He is ready to make me a deal, and pushing me to do this. He is a bad influence. I need shipping weights...
It takes gasoline to interest me.
[Re: feets]
#1208496
04/16/12 03:47 AM
04/16/12 03:47 AM
Posts: 480 Texas
racer_amx
Texas
+1
[Re: Rug_Trucker]
#1208498
04/16/12 03:01 PM
04/16/12 03:01 PM
VL21
central Florida
One of those Nissan 6 bangers? Dealer swapped?
IIRC you could get a Dodge pickup with one of those Nissan turds.
You might be thinking of the 77-78 Mitsu diesels, never personally seen one, just in pics.
[Re: dogdays]
#1208500
04/16/12 09:11 PM
04/16/12 09:11 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
Whoever owns the car can do as they please... if they didn't weigh so much I'd do it to my challenger for something different.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: kilroy]
#1208502
04/17/12 11:37 AM
04/17/12 11:37 AM
DPelletier
The real answer is WHY WOULD YOU EVEN BOTHER? Why would you put a 1200 lb low-rpm engine into a car designed to go fast and handle, at least a little?
If you're looking for fuel economy GET A DIFFERENT CAR!
The prices of any MOPAR muscle car have gone so high that to bastardize one with a Diesel engine makes no sense whatsoever. When you can't even get close to a decent E-body builder for less than $8,000, you tow your musclecar to wherever you need with your Cummins Diesel truck! Maybe, just maybe in an Imperial it would make sense. But there have got to be better Diesel engines for automotive use than that Cummins. And no musclecar deserves a smoker. Period.
R. (I feel better now)
Feel better about what, being an idiot? Let him do as he pleases.
Im going to scrap my 90 dodge and put its CTD in a 51 ford truck, some say thats blasphemy.
I have a friend who would LOVE to try to put a CTD in a roadrunner. I think its interesting and would love to see a finished product.
A '51 Ford truck (assuming you put all the related HD stuff in); great! A roadrunner? ...doesn't make any logical sense at all but it's his car I guess....
1974 'Cuda
