Re: Well, going to try something different...
[Re: don miller]
#1208142
04/03/12 02:31 PM
04/03/12 02:31 PM
Posts: 1,600 Alberta Canada
StrokerAspen
Alberta Canada
There were two inherent "problems" with the original leaf link. First clamping the spring solid to the pivot created a bind, you could ease that by having the spring slide in the pivot. Second issue was even with ss prings it would kill the spring at the front eye very quickly. Calvert addresses this with their monos being much thicker than even the old made in Canada ss springs. Despite these correctable shortcomings they did work but were shelved when Jenkins tilted the playing field when he debuted his Vega
I don't think this is why Calvert has done a thick mono leaf. If you put a true leaf spring car on a four corner scale, then drive it around the block, and put it back on the scales, your readings will be different. Leafs bind on each other. The mono leaf is a more constant spring. When the Caltracs are under load, those monos are in tension. In the leaf link, the leaf is unfortunately in compression.
-Kenny
[Re: StrokerAspen]
#1208145
04/04/12 11:21 AM
04/04/12 11:21 AM
Posts: 5,488 SoCal
Brian Hafliger
SoCal
Hey Kenny, I tried returning your dads phone call but I think I'm missing a digit...I tried PM'n you but your box is full. Brian
Brian Hafliger
[Re: Brian Hafliger]
#1208146
04/04/12 11:48 AM
04/04/12 11:48 AM
StrokerAspen
Alberta Canada
Oops! Going to have to clean it out!
Here is the shop info...
www.josstechnical.com
403-320-7272
Thanks.
-Kenny
[Re: StrokerAspen]
#1208148
04/06/12 06:11 AM
04/06/12 06:11 AM
Posts: 1,170 MI
68shifter
MI
Looks good man! Good to see a different setup being tried. I'd like to see how the results turn out all said and done. Good luck.
68' Barracuda (4 speed)
64' Savoy (4 speed)
65' Satellite (girl tranny)
[Re: StrokerAspen]
#1208149
04/06/12 12:52 PM
04/06/12 12:52 PM
Posts: 661 Alberta
rustbuckett68
Alberta
These them?
[Re: rustbuckett68]
#1208152
04/06/12 01:54 PM
04/06/12 01:54 PM
Posts: 21,208 in a cattle trailer down by th...
Guitar Jones
So basically the leaf spring becomes the lower bar of a four link. That is going to be in compression then as stated earlier. I can see where that would cause a lot of stress on the spring.
"Come get your wife"
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Front and rear disc and hydroboost conversion. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: StrokerAspen]
#1208158
04/12/12 11:31 AM
04/12/12 11:31 AM
StrokerAspen
Alberta Canada
I was able to get some more measurements off the car for the final rear pieces to get cut and bent up. I had a chromoly cross member bent up to mount off of for the top links to hook to. After measure up on the rear end of the car we started hacking and chopping the front of car up to fit the front QA1's. The stock shocks in an FJM Body are too short for shock companies to build a truely adjustable front shock. There isn't enough room to put the valving in the shock body. I will have to get some pictures next time I'm out there. ThIngs are getting tight in the back end haha! It should look about right though in my opinion when it's sitting on the ground. -Kenny
[Re: StrokerAspen]
#1208160
04/22/12 06:17 PM
04/22/12 06:17 PM
Posts: 4,219 New York
polyspheric
New York
First: more power to you, and anyone else who tries to improvise.
My knowledge of suspension tuning is very slight. What I can offer is a prediction of how sanctioning bodies deal with innovation.
1. if you mail them a diagram and explanation and ask for a ruling, they will not give you legal status in writing 2. personal and phone conversations never took place, didn't go the way you said etc. 3. the tech line is only concerned with safety rules - not legality 4. being permitted to race doesn't mean that they agree that you're legal 5. nothing will happen until you beat someone important/influential - you know, the guys married to Force's cousin, blah 6. when protested you fail
The reason given may take various forms as to language, beginning by simply stating the "it's not in the rules" (actual non-compliance). Your objection that it's not prohibited will be met with "it violates the spirit of the rule" (translation: we don't like you). The underlying reason is simple: you beat someone more important than you. IMHO it's not legal, in that you're not using the suspension in a different way. It would fail an objection based on patentable engineering features (not enough commonality with OEM). There are 2 main points of difference: 1. the original leaf was both the entire suspension and the locator for the axle, now it's not 2. a new part has assumed some of the original function, which is not stock
Boffin Emeritus
[Re: polyspheric]
#1208161
04/22/12 06:52 PM
04/22/12 06:52 PM
Posts: 10,155 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I am betting it will work great if two areas are addressed? Strength of the front half of the lower leaf. Stiffening it with another leaf that goes all the way to the spring eye may do the trick, but never tried it. The other thing on my mind is freedom of spring rate. If the shackles are too short or at the wrong angles, things get goofy. I am betting if these items are addressed, along with instant center being adjustable it should work like a four link.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
