Re: Race Car Stance (opinions needed)
[Re: bonefish]
#1207490
04/01/12 05:50 PM
04/01/12 05:50 PM
My taste would be set at zero, I like a slight rake but not too much.
[Re: MR_P_BODY]
#1207491
04/01/12 05:52 PM
04/01/12 05:52 PM
Posts: 2,709 NJ central
Scamp408
NJ central
Also... when you showed the back up... were you lifting it on the rear end... didnt really see an difference in the tire to wheel well
I jacked up the from the tank/trunk well area and measured 1in difference on the lip .
[Re: Scamp408]
#1207492
04/01/12 05:58 PM
04/01/12 05:58 PM
Posts: 52,972 Romeo MI
MR_P_BODY
ok... wasnt sure if I seen a difference
[Re: OUTLAWD]
#1207493
04/01/12 05:59 PM
04/01/12 05:59 PM
Scamp408
NJ central
0...I like a little tuck...not in the weeds, but not stick bug...
What size you got on the back?
With the stock width axle, I just have to jack up by the body to slide the tires off
325 50 15 if I jack the body up its real tight but I can get on and off but a pain. The split monos dont let the rear hang that low .
[Re: MR_P_BODY]
#1207495
04/01/12 06:11 PM
04/01/12 06:11 PM
Scamp408
NJ central
Just an inch . I wonder if the monos will sag out.
[Re: MR_P_BODY]
#1207497
04/01/12 06:44 PM
04/01/12 06:44 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
ive had my monos on a 4,000 lb car for 7 years if they have sagged (and they probably have)its not enough to notice.
[Re: Cab_Burge]
#1207505
04/02/12 05:31 PM
04/02/12 05:31 PM
Scamp408
NJ central
I like the fastest time slip, try it both ways and see Can you fit the 315x60x15 on your car
Width wize she will fit but height no unless I do the plus 1
[Re: Scamp408]
#1207506
04/02/12 05:42 PM
04/02/12 05:42 PM
Posts: 19,395 Las Vegas
Al_Alguire
Las Vegas
Well for looks I prefer the 0 stance or -1. BUT what matters is having it where it works best. Unless looks are more importatn to you than winning rounds are. Then by all means have it sit whatever way you prefer.
[Re: Bigcube]
#1207507
04/02/12 10:37 PM
04/02/12 10:37 PM
Posts: 3,101 cincinnati ohio
mcat4321
cincinnati ohio
How about -1? I like them low, never cared for the jacked up in the back look.
this
[Re: StrokerPost]
#1207508
04/03/12 12:36 AM
04/03/12 12:36 AM
Posts: 3,427 Toronto
mshred
Toronto
Lower definately looks better. Keep that butt outta the breeze.
x2
the +1 looks way too high, and I cant imagine the extra height making the car work any better
