Page 2 of 3 1 2 3
Re: Race Car Stance (opinions needed) [Re: bonefish] #1207490
04/01/12 05:50 PM
04/01/12 05:50 PM
My taste would be set at zero, I like a slight rake but not too much.
Re: Race Car Stance (opinions needed) [Re: MR_P_BODY] #1207491
04/01/12 05:52 PM
04/01/12 05:52 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
Also... when you showed the back up... were you lifting
it on the rear end... didnt really see an difference
in the tire to wheel well
I jacked up the from the tank/trunk well area and measured 1in difference on the lip .
Re: Race Car Stance (opinions needed) [Re: Scamp408] #1207492
04/01/12 05:58 PM
04/01/12 05:58 PM
MR_P_BODY Offline
MR_P_BODY  Offline
ok... wasnt sure if I seen a difference
Re: Race Car Stance (opinions needed) [Re: OUTLAWD] #1207493
04/01/12 05:59 PM
04/01/12 05:59 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
0...I like a little tuck...not in the weeds, but not stick bug...
What size you got on the back?
With the stock width axle, I just have to jack up by the body to slide the tires off
325 50 15 if I jack the body up its real tight but I can get on and off but a pain. The split monos dont let the rear hang that low .
Re: Race Car Stance (opinions needed) [Re: Scamp408] #1207494
04/01/12 06:09 PM
04/01/12 06:09 PM
where its cold and white durin...
2QUICK4U Offline
2QUICK4U  Offline
-1
Re: Race Car Stance (opinions needed) [Re: MR_P_BODY] #1207495
04/01/12 06:11 PM
04/01/12 06:11 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
Just an inch . I wonder if the monos will sag out.
Re: Race Car Stance (opinions needed) [Re: Scamp408] #1207496
04/01/12 06:19 PM
04/01/12 06:19 PM
MR_P_BODY Offline
MR_P_BODY  Offline
That I dont know.... but all spring sag after time
but I know you are asking if its right away
Re: Race Car Stance (opinions needed) [Re: MR_P_BODY] #1207497
04/01/12 06:44 PM
04/01/12 06:44 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
ive had my monos on a 4,000 lb car for 7 years if they have sagged (and they probably have)its not enough to notice.
Re: Race Car Stance (opinions needed) [Re: bonefish] #1207498
04/01/12 10:21 PM
04/01/12 10:21 PM
cleveland Ohio
mloboda Offline
mloboda  Offline
cleveland Ohio
You know what i like.
Re: Race Car Stance (opinions needed) [Re: mloboda] #1207499
04/02/12 02:30 PM
04/02/12 02:30 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
Thanks for everybodys help I like it both ways lol. I am going to leave for now and run it.If it rubs than
i will go with the plus 1 springs instead I will order my shocks. It never ends .
Re: Race Car Stance (opinions needed) [Re: Scamp408] #1207500
04/02/12 02:58 PM
04/02/12 02:58 PM
Cab_Burge Online work
Cab_Burge  Online Work
I like the fastest time slip, try it both ways and see Can you fit the 315x60x15 on your car
Re: Race Car Stance (opinions needed) [Re: Scamp408] #1207501
04/02/12 03:32 PM
04/02/12 03:32 PM
London,Ontario,Canada
1962Savoy Offline
1962Savoy  Offline
My worth!!
Re: Race Car Stance (opinions needed) [Re: 1962Savoy] #1207502
04/02/12 03:49 PM
04/02/12 03:49 PM
SO CAL
BB70DUSTER Offline
BB70DUSTER  Offline
SO CAL
-3"
Re: Race Car Stance (opinions needed) [Re: BB70DUSTER] #1207503
04/02/12 03:52 PM
04/02/12 03:52 PM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
1st pic.
Re: Race Car Stance (opinions needed) [Re: Scamp408] #1207504
04/02/12 04:42 PM
04/02/12 04:42 PM
Missouri
StrokerPost Offline
StrokerPost  Offline
Missouri
Lower definately looks better. Keep that butt outta the breeze.
Re: Race Car Stance (opinions needed) [Re: Cab_Burge] #1207505
04/02/12 05:31 PM
04/02/12 05:31 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
Width wize she will fit but height no unless I do the plus 1
Re: Race Car Stance (opinions needed) [Re: Scamp408] #1207506
04/02/12 05:42 PM
04/02/12 05:42 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Well for looks I prefer the 0 stance or -1. BUT what matters is having it where it works best. Unless looks are more importatn to you than winning rounds are. Then by all means have it sit whatever way you prefer.
Re: Race Car Stance (opinions needed) [Re: Bigcube] #1207507
04/02/12 10:37 PM
04/02/12 10:37 PM
cincinnati ohio
mcat4321 Offline
mcat4321  Offline
cincinnati ohio
How about -1? I like them low, never cared for the jacked up in the back look.
this
Re: Race Car Stance (opinions needed) [Re: StrokerPost] #1207508
04/03/12 12:36 AM
04/03/12 12:36 AM
Toronto
mshred Offline
mshred  Offline
Toronto
x2
the +1 looks way too high, and I cant imagine the extra height making the car work any better
Re: Race Car Stance (opinions needed) [Re: mshred] #1207509
04/03/12 12:48 AM
04/03/12 12:48 AM
Alberta Canada
E
Edge Offline
Edge  Offline
E
Alberta Canada
0 or lower if possible
76 Duster work in progress
Page 2 of 3 1 2 3
