Re: small block indy head or 3g Hemi
[Re: ZIPPY]
#1206667
03/31/12 07:53 PM
03/31/12 07:53 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
Matt you've been all about the Gen 3 hemi for long enough to where I can't imagine you doing anything anything else.
If all the LA stuff was up for sale reasonable enough, I'm sure it'd be sold in no time.
Yes I know I think I need help. I'm am a hoarder. Need an intervention So many options. XR block come in aluminum. BPE has a 360 main 4.25 stroke crankshaft coming out. Will probably try to sell my R3 and Indy stuff to see what I can get for it. Lets see what the price difference are between and R3 and G3 Block R3 Siamese 2800.00 Not including all the machining work that you need extra for lifters and oil drainback 0r lightning of the boat anchor. G3 production block anywhere from 250 to 1000.00 Rotating assembly about the same on both sides Cylinder heads about 5000.00 for Indyand that includes the crappy rockers and intake. G3 less than 2000.00 cnc 1000.00 intake
Head gaskets 150.00 cometic G3 stock 45.00 Head studs 120.00 G3 stock 40.00 ignition system about the same OIl Pans the same Am I missing something
[Re: MattW]
#1206668
03/31/12 08:19 PM
03/31/12 08:19 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
This is why we'll be working hard to make carbed hemi's cheap and easy.
Brian Hafliger
[Re: mshred]
#1206670
04/01/12 03:51 PM
04/01/12 03:51 PM
Posts: 2,864 IN
Irun5snd8th
IN
After Rick posted his dyno results, it seems that its a no brainer especially for a guy like you thats been all about the new Hemi stuff.
AFCO, Rons Fuel Injection sponsored Dodge Challenger
Mention Street Lethal Motorsports
