Hemi swap power steering pressure reduction
#1203848
03/26/12 01:26 PM
03/26/12 01:26 PM
Posts: 738 Oh Canada
EV2CUDA
Oh Canada
How does one go about modifying the original pump to reduce its pressure? I want to keep it. There must be a way. Its a 5.7 from a truck.
71 Barracuda 383 4spd (500ci) 69 camaro 598, NOS 69 barracuda bbc procharger 77 t/a 6.0 turbo project 78 t/a 400 77 corvette 1983 hurst/olds 03 Viper 79 360 macho 71 demon 360 78 Warlock 5.7 hemi project
Re: Hemi swap power steering pressure reduction
[Re: JDMopar]
#1203850
03/27/12 11:26 AM
03/27/12 11:26 AM
EV2CUDA
Oh Canada
There must be a way. I don't like the separate reservoir and the expense. I have read it can be done.
[Re: jlatessa]
#1203853
03/27/12 08:54 PM
03/27/12 08:54 PM
EV2CUDA
Oh Canada
No. The new hemi pumps put out nearly double the pressure of old. Or at least more than necessary
[Re: jlatessa]
#1203854
03/27/12 09:41 PM
03/27/12 09:41 PM
Posts: 440 Arizona
69rrconvert
Arizona
Are you talking about an older pump, i.e. 60s-70s?
I modified my 71 pump per one of the MOPAR mags. It entails pulling out the valve on the back of the pump and adding a shim washer, (I used a brass washer that I had to file the O.D. a little) .030" thick if I remember correctly.
Haven't tried it yet, but it is supposed to reduce the boost to more acceptable levels. It really is what MOPAR did by using the same pumps on smaller cars, (Valiant, Dart) with different shim packages.
I'll try to find out which mag it was, I have it somewhere.
Joe
I used the power steering pump that was on the 5.7 engine. No problems with excessive pressure
[Re: JDMopar]
#1203856
03/28/12 12:38 AM
03/28/12 12:38 AM
EV2CUDA
Oh Canada
It is for the warlock. And I do want to keep the a/c. Ill give it a try the way it is. The demon has standard steering box so no problems there.
