Heres another option if originality is not an issue. These are from a 2006 Toyota tundra. It has the dogbone that rotates, that you need for proper placement across chest. This dogbone is also adjustable for easy transitions between taller and shorter passengers. Here are some pics of the dogbone fully extended and shortened, and there are other stopping points in between. Theres also a pic of the retractor. Its an option that Im seriously considering because I want 3 point seat belts, and Im also trying to put the front buckets and rear bench from a new charger into my Satellite.
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
