F8 Plymouth Paint Code #1200517
03/20/12 10:25 PM
03/20/12 10:25 PM
NY
Beep Beep Offline OP
NY
Hi,
Does anyone know the correct F8 paint code for a 1969 Roadrunner? Thanks
Re: F8 Plymouth Paint Code [Re: Beep Beep] #1200518
03/20/12 10:39 PM
03/20/12 10:39 PM
cbusters Offline
cbusters  Offline
Is F8 the Rally Green that started mid year?
Re: F8 Plymouth Paint Code [Re: cbusters] #1200519
03/20/12 10:43 PM
03/20/12 10:43 PM
NY
NY
Sorry not sure?
Re: F8 Plymouth Paint Code [Re: Beep Beep] #1200520
03/20/12 11:17 PM
03/20/12 11:17 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
my 69 gtx has a f7 exterior and a f8 int.when i painted it 10 years ago all i told the paint store was plymouth f7 and they got it perfect.
Re: F8 Plymouth Paint Code [Re: bonefish] #1200521
03/21/12 12:43 AM
03/21/12 12:43 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
There were 3 greens available on a Road Runner for the full 1969 model year.
F3 - "frost green metallic"
F5 - "limelight metallic"
F8 - "ivy green metallic"
& a mid-year special order "rallye green metallic" usually with code 99.
Those are the Chrysler Corp. codes for the colors, what are you asking? Do you want the codes/formulas for a specific brand of paint? What brand, what line?
Re: F8 Plymouth Paint Code [Re: 6bblgt] #1200522
03/21/12 06:08 AM
03/21/12 06:08 AM
NY
NY
Yes I am looking for the formulas. Not sure of the brand of paint. I will have to see what brand the store sells.
Re: F8 Plymouth Paint Code [Re: 6bblgt] #1200523
03/21/12 06:13 AM
03/21/12 06:13 AM
Port Huron, Michigan
MI_Custumz Offline
MI_Custumz  Offline
Rallye Green metallic is also 97 on the fender tag of a friend's A12 Runner. I think the color is the same or real darn close to the 69 Camaro green.
Re: F8 Plymouth Paint Code [Re: Beep Beep] #1200524
03/21/12 08:41 AM
03/21/12 08:41 AM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
You will need to know what brand of paint first. Any reputable piant shop or body shop will be able to look up the forumula. Make sure they get the right year though as the paint formula may change from year to year with the same fender tag paint code. Most good paint shops have a coumputer that can determine the right forula and give it to them in the various type of paint (singel stage, BCCC, etc).
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: F8 Plymouth Paint Code [Re: RoadRunner] #1200525
03/21/12 10:13 AM
03/21/12 10:13 AM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: F8 Plymouth Paint Code [Re: DPelletier] #1200526
03/21/12 10:15 AM
03/21/12 10:15 AM
DPelletier Offline
DPelletier  Offline
Re: F8 Plymouth Paint Code [Re: DPelletier] #1200527
03/21/12 10:16 AM
03/21/12 10:16 AM
DPelletier Offline
DPelletier  Offline
Re: F8 Plymouth Paint Code [Re: DPelletier] #1200528
03/21/12 10:23 AM
03/21/12 10:23 AM
DPelletier Offline
DPelletier  Offline
I tried a couple different paints before doing my car. I don't have the number here at work but I can get it if you like.
Re: F8 Plymouth Paint Code [Re: RoadRunner] #1200529
03/21/12 03:48 PM
03/21/12 03:48 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
I agree with this. I went to a dealer, maybe PPG, and what they had to offer was the color coat in a medium priced quality and a clear coat that raised the overall quality to top of the line.
The 69 Plymouth Service Manual, page 23-151 says, "F8, Ivy Green Metallic, Chrysler Code AY2EF8, Ditzler Code *43786", where * means carry-over color.
If anyone is interested, here's F8, the medium green, compared to F5, the light green, in bright sun. Jusy like your bottom (maybe), this paint had never seen the light of day, until this moment, because it is the inside surface of the door, under the door panel.
Re: F8 Plymouth Paint Code [Re: kentj340] #1200530
03/21/12 04:09 PM
03/21/12 04:09 PM
DPelletier Offline
DPelletier  Offline
Actually EF8 = Dark Green Metallic (actual Dodge name for it - Plymouth calls it Ivy); EF5 = Medium Green Metallic (Plymouth Limelight) and EF-3 is Light Green Metallic (Plymouth Frost Green Met.)
I was lucky enough to find a perfect sample of paint under my front windshield rubber that was never exposed to the elements and I used that for my color match. Of course, lighting, cameras and computer monitors all play a part. For example;
the garage under flourescent lights:
Re: F8 Plymouth Paint Code [Re: DPelletier] #1200531
03/21/12 04:10 PM
03/21/12 04:10 PM
DPelletier Offline
DPelletier  Offline
the light of day;
Re: F8 Plymouth Paint Code [Re: DPelletier] #1200532
03/21/12 04:12 PM
03/21/12 04:12 PM
DPelletier Offline
DPelletier  Offline
blinds in the shop open;
Re: F8 Plymouth Paint Code [Re: DPelletier] #1200533
03/21/12 04:13 PM
03/21/12 04:13 PM
DPelletier Offline
DPelletier  Offline
another;
Re: F8 Plymouth Paint Code [Re: DPelletier] #1200534
03/21/12 09:20 PM
03/21/12 09:20 PM
NY
NY
Thanks everyone for the feedback. So in 1969 plymouth called it ivy green and dodge called it dark green, were the colors the same? DPelletier if you have the mix that would be great. My tag calls for f8 and my car was painted 15 years ago from the previous owner. I did find the mix sheet and it states 1969-1970 chrysler f8 jade green met. 4988k chromabase
Re: F8 Plymouth Paint Code [Re: Beep Beep] #1200535
03/22/12 10:16 AM
03/22/12 10:16 AM
DPelletier Offline
DPelletier  Offline
Yes, EF8 = EF8 no matter what it's called. I'll dig out the info in my shop. Hopefully tonight.
Re: F8 Plymouth Paint Code [Re: DPelletier] #1200536
03/22/12 09:26 PM
03/22/12 09:26 PM
NY
NY
Thanks DPelletier
