Re: So anyone try the MSD atomic EFI yet?
[Re: deansrr]
#1200511
03/22/12 01:14 PM
03/22/12 01:14 PM
Posts: 3,533 Indiana
Fury Fan
Indiana
As far as replacement sensors - Most every aftermarket system I have investigated standardized on GM-type sensors, meaning the sensor resistance curves are comparable to what GM used. There are a plethora of variations in the aftermarket regarding wiring connectors, mounting threads, etc, but if you're needing a replacemnt part ASAP you'll probably be able to get something that would work, or could be rigged in temporarily, at a parts store. Looking at a part for a 1990 GM __________ is a good starting point.
And for any home-brewed JY EFI system, unless you get it all for free you better plan on spending at least $500 minimum. A new 45 PSI pump will run $80 minimum, fuel lines and fittings aren't free, you'll want new sensors ($50 easily) - it adds up quick. A junkyard ECU will be $50 minimum, too.
And there's a TON of info and upgrade parts out there for the GM TBI system, and even though TBI is frowned upon it still offers lots of benefit over a carb.
OK, sidetrack over...
[Re: Fury Fan]
#1200512
03/26/12 06:22 PM
03/26/12 06:22 PM
Posts: 2,034 NW Indiana
deansrr
NW Indiana
Well went ahead and order parts today, Atomic efi, dist, coil and rotor, free 6A box, by rebate, save myself over $228. Suppose to get car back late April, can wait to install!! anyboby need a quikfuel E85 Carb!!
1973 Road Runner
1974 Satellite (for sale)
1973 240z (wifes)
1993 Ramcharger (thanks Devil)
2002 Honda S2000
[Re: deansrr]
#1200513
03/26/12 09:37 PM
03/26/12 09:37 PM
Posts: 3,704 MICHIGAN
DynoDave
MICHIGAN
Cool. I look forward to hearing about your install, and the results! ![](/ubbthreads/images/graemlins/drive.gif)
[Re: deansrr]
#1200514
06/04/12 07:47 PM
06/04/12 07:47 PM
Posts: 3,001 Coram, NY
Pool Fixer
Coram, NY
sorry to dredge up such an old thread, but did you get your EFI up and running?
[Re: Pool Fixer]
#1200515
06/04/12 09:35 PM
06/04/12 09:35 PM
Posts: 299 East Brunswick, NJ
finadk
East Brunswick, NJ
UPS will be delivering mine tomorrow! I am however still WEEKS away from having the car to the point where I can try to run it.
Scott
1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed)
2002 Dodge Ram 1500 Quad Cab
1976 Corvette
[Re: finadk]
#1200516
06/11/12 02:07 AM
06/11/12 02:07 AM
Posts: 322 Itasca, Texas
Mad_Scientist
Itasca, Texas
I installed it on my 440 a few months ago and I love it. Just answered a few questions and it started right up. There is some manual tuning that you have to do, but it is simple. Took the car on a 400 mile trip a few weeks after the install and had no problems. It was well worth the money, in my opinion. I did an in tank pump install with my kit.
69 Super Bee 440 5-speed 70 Dart Swinger 340 4-speed 69 Camaro SS 396 4-speed 66 Cutlass Convertilbe 70 Judge Ram Air III 4-speed 68 F-100 SWB
