Hemi Landy rocker arm oiling question.
#1198995
03/18/12 05:02 PM
03/18/12 05:02 PM
Posts: 4,848 Memphis
HemiRick
Memphis
I understand these rockers leak too much oil, and to cure this I intend to install .075 oil restrictors in the block based on Bob George's reccomendation. I am also going to run pushrod oiling w .040 restrictors.
The question is should I also attempt to plug up some of the oilling holes in the rockers ? My intake rockers have 2 holes and the exhausts only 1. If so how?
My thinking here is that with the oilling restrictors and all these oil leaks that the oil will just dribble and not stream outta the holes, thus having no practical value. I figure the holes aimed at the pushrods certainly aren't needed with the pushrod oilling.
Thanks Rick
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Hemi Landy rocker arm oiling question.
[Re: HemiRick]
#1199000
03/21/12 12:53 PM
03/21/12 12:53 PM
HemiRick
Memphis
bump still hoping to find an informed opinion on this....
[Re: HemiRick]
#1199001
03/21/12 01:18 PM
03/21/12 01:18 PM
Posts: 1,505 TN
SCATPACK 1
TN
Rick I am watching this post too and I hope to see something from someone with experience post. I also want to know about the Landy Rockers. Aren't these rockers cast out of Stainless? I wonder if the oil holes could be welded up without hurting the brass inserts. I do not see a need for the oil holes to be open on the pushrod side when you are using oil thru lifters/pushrods. What lifters (part #) are you using for the oil thru.
Old Geezer Racing
[Re: SCATPACK 1]
#1199002
03/21/12 01:30 PM
03/21/12 01:30 PM
HemiRick
Memphis
Yes I believe these rockers are stainless. I was thinking something less hot like soldering or brazing the holes, I was also thinking that JB weld or some other epxoy would work fine too.
I got my solid roller lifters from Best Machine and they are made by Morel I think.
[Re: HemiRick]
#1199003
03/21/12 04:48 PM
03/21/12 04:48 PM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
Thanks Rick
My opinion would be to plug the holes if you going to use pushrod oiling. Pushrod manufacturers like Manton can put the restrictors in when they make them.
For me, I'd be leary using epoxy or JB weld in case it comes out.
I was thinking may a small set screw? Thread the holes and install the set screws with lock tight. That way if you ever want to go back or sell them to someone that doen't use push rod oiling, they can pull the set screws and use conventional oiling.
[Re: B G Racing]
#1199005
03/22/12 01:19 PM
03/22/12 01:19 PM
HemiRick
Memphis
Bob your reply was the one I was waiting for, but I dont understand. Quote:
The oil will pass through the pushrod then through the rocker oil passages.
This seems to imply that my adjuster screws are drilled, but mine are not.
There will not be a sufficient quanity of oil in the shafts to flow through the existing shaft and the side holes in the rockers.
Thats why I want to block all the holes except the ones in the intakes that try to oil the intake roller.
[Re: HEMIFRED]
#1199008
03/22/12 05:49 PM
03/22/12 05:49 PM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
another version done by someone else
home of the Sox and Martin Hemi Duster
[Re: HemiRick]
#1199010
03/22/12 11:02 PM
03/22/12 11:02 PM
Posts: 914 tn
robnbird
tn
My thinking here is that with the oilling restrictors and all these oil leaks that the oil will just dribble and not stream outta the holes, thus having no practical value. I figure the holes aimed at the pushrods certainly aren't needed with the pushrod oilling. If you are going to run oil thru push rods , with oil thru lifter you have the rocker ball cup oiling problem fixed. instead of pluging the oil holes in the rockers whay not restrict the block oil hole to .040 or so. My question is are you useing a world block and which lifter are you going to use? Rob Thanks Rick
[Re: robnbird]
#1199011
03/23/12 12:41 AM
03/23/12 12:41 AM
HemiRick
Memphis
My question is are you using a world block and which lifter are you going to use? Rob
Nope early Mega block and lifters are Morels bought from Best Machine. Using a .075 restriction because its what BG suggested. With head gaskets being $66 ea, I want to get the right size restrictors in there the 1st time.
Anyone else have any input on restrictor size?
Looking for an old beat up valve cover to cut up so I see the valvetrain oiling, can anyone help?
I intend to install restrictors and and plug all the holes in the rockers except the one that points at the intake roller. Then visually see if the 1 hole is squirting where it needs to and go from there.
[Re: HEMIFRED]
#1199012
03/23/12 08:55 AM
03/23/12 08:55 AM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
Fred,I meant no disrespect by the term"band aid".Sorry for the bad choise of words .I did say that many have come up with elaborate solutions for the issue but we in most all cases correct the problem with the stock way it was ment to oil.Making all those setup can be costly and time consuming. Even with the Indy,Norris and Landy rockers we drilled to direct the oil where it was needed in some cases and drilled out head bolt hole that has the oil passage or turned down the head stud diameter to allow more oil flow to the rocker shafts.We have also champhered the hole in the rocker shaft. On some like Landy and Indy we drilled a hole in the side barrel to squirt oil on the spring,retainer and roller tip.
[Re: 3ddart]
#1199014
03/23/12 12:02 PM
03/23/12 12:02 PM
HemiRick
Memphis
Yea I saw tour post about these covers earlier. The are nice but cost way more than I'm willing to spend on this project. I need to find a bashed rusted steel valve cover for cheap.
