Slant 6 and 4 on the floor?
#1198599
03/17/12 09:01 PM
03/17/12 09:01 PM
Posts: 952 Stockholm, Sweden
MrSixpack
Stockholm, Sweden
was there any slant 6 with 4 on the floor. I'm thinking of putting a 4 speed in my charger with a slant 6. What do you think ![](/ubbthreads/images/graemlins/beer.gif)
1970 Super Stock Challenger ex. Paul Rossi 1968 Dodge Dart GT 340 1968 Dodge Charger /6 3 speed manual 1966 Chrysler 300 Loaded 1968 Dodge Charger R/T 440
1968 Mini Cooper
Re: Slant 6 and 4 on the floor?
[Re: MrSixpack]
#1198600
03/17/12 09:03 PM
03/17/12 09:03 PM
[Re: MrSixpack]
#1198604
03/17/12 11:13 PM
03/17/12 11:13 PM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
Great idea! You will need a 4 speed slant bell housing for the 833OD.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
[Re: RUMBLON]
#1198608
03/18/12 07:45 AM
03/18/12 07:45 AM
MrSixpack
Stockholm, Sweden
My 68 charger is black on black and was original /6 with 3 on the tree. It had a 7 1/4 with 2.73 but it was so bad I throw it in the trash. The column shifter is in so bad condition and I can't find any parts over here. So I was thinking of the 833 tranny I have from a 383 and rework the /6 bellhousing to fit it. Yes I know I'm ![](/ubbthreads/images/graemlins/laugh2.gif) (It's one of only four made according to Galen)
1968 Mini Cooper
[Re: MrSixpack]
#1198609
03/18/12 12:58 PM
03/18/12 12:58 PM
Rug_Trucker
Keeping the slant and adding a 4 speed and turbo would really mess with people's heads. It won't be as fast as a V8. If you want to stay slant? Come on over to www.slantsix.org There is some great turbo builds going on. What rear, and gear do you have now?
[Re: slantzilla]
#1198615
03/19/12 12:12 AM
03/19/12 12:12 AM
Posts: 8,020 Pangaea
B5 Bee
Pangaea
Unless you have a lot of rear gear you will really beat up your clutch trying to get it moving. That is why they used the 3.09 low gear with Slants.
That's why I went with a 3.91 in my D100. The 3.09 low and original 3.21 rear gear was fine when empty. With the trailer on the back, it took a bit of clutch dust to get it moving. Now with the 3.91, the only time I have to ride the clutch with a load is on a steep incline.
[Re: B5 Bee]
#1198616
03/19/12 08:40 AM
03/19/12 08:40 AM
Posts: 416 Franklin Co. Illinois
runinonmt
In '66 I tuned up a Barracuda /6 4 sped for the district service rep. so yeah,they did exist but weren't common. It did confirm my belief that rowing through the gears makes any car more fun. Ron
In sixty-five I was seventeen and running up one-o-one
I don't know where I'm running now, I'm just running on
Jackson Browne-Running On Empty
[Re: MrSixpack]
#1198617
03/19/12 11:16 AM
03/19/12 11:16 AM
Posts: 12,245 Looking for a way out of Middl...
IMGTX
I did this on my /6 Barracuda. Here is the long and short of it. You have 3 problems to overcome. Bellhousing, Clutch Fork, & Clutch Linkage. You need a bellhousing with a 4 speed bolt pattern so you can bolt an 833 to it. Back in the sixties they did make some 4 speed /6 bellhousings but they are virtually impossible to find here, over there, I doubt it is going to happen. Plan B: Later model Trucks/Cars had a dual bolt pattern bellhousing for the slants. Unfortunately they are all overdrive. But this is an easy fix. You can; Run an Overdrive Transmission. Swap transmission parts around until you get a standard gearset in an overdrive housing. OR Machine an adapter to adapt the non overdrive transmission's input shaft bearing retainer to an overdrive bellhousing. Brewers or Passon probably sell one but I made mine. 2nd Problem, is the overdrive bellhousings usually (maybe always?) used a different clutch fork. It used a ball pivot instead of the tab pivot that most older mopars used and it is longer. They need to be a matched set, Bellhousing & Fork buy them both together. 3rd problem is the Z-Bar. It must reach from the frame to the engine and line up with the clutch pedal rod & Clutch fork. Older /6 cars used a very long Z-bar and will probably not line up with the clutch for from an overdrive bellhousing. A z-bar from a later model car would probably be too short or not line up with the clutch pedal rod. I made a freaky looking adapter that bolted to my Z-bar and added a pivot further to the drivers side that was aligned to the clutch fork. It is heavy (about 6oz) but I didn't have to modify my original fork. The factory clutches were pretty springy so it works fine. If I were to do it again I would buy a spare one from Brewers/Passon and have the lever moved over. They may be able to do it for you. I did notice a late model truck with a hydraulic clutch fork in the JK once, it may be an option also. Good news is that I think all /6's used the same diameter flywheel just different pressure plate bolt patterns so I do not think you will run into a problem like the V8's where they made 11" and 10.5" flywheels that won't interchange inside bellhousings. Somebody correct me if I am wrong. ![](/ubbthreads/images/graemlins/shruggy.gif) I hope it helps. ![](/ubbthreads/images/graemlins/thumbs.gif)
