331 HEMI question
#1196545
03/13/12 07:26 PM
03/13/12 07:26 PM
Posts: 12,031 Finally a HUSKER again
Moparnut426
My buddy bought a 331 out of a 52 chrysler, I got it freed up, had 2 stuck vlaves, and a rough cylinder, nothing teribly bad. So Im looking at the extended block at the rear, and was wondering if anyone has ever milled off the rear portion of the block, and made an adapter plate say out of 1/2" material, and mated a standard mopar small block bell housing to it?
He wants to run a newer 4 speed, and I have an 833 laying around, and a spare bell housing id rebuild for him, but I dont know if this has ever been done before. Sounds simple enough, but would require some very good machining, and centering.
Is there a "kit" out there for this? I kinda reserched it and came up with zilch.
He is building a 30s model international rat rod, and got a good deal on the ol HEMI.
Kasey
Re: 331 HEMI question
[Re: Dougsmopars]
#1196550
03/13/12 09:29 PM
03/13/12 09:29 PM
Posts: 1,531 AZ
Mike P
AZ
".....He is building a 30s model international rat rod, and got a good deal on the ol HEMI....."
Not trying to be a smart a$$ but the reason the extended bellhousing 331 are cheap is because of the transmission issues and they have the least deseriable smalll valve/small port heads. They also cost as much as the better HEMIs to rebuild.
".....was wondering if anyone has ever milled off the rear portion of the block, and made an adapter plate say out of 1/2" material, and mated a standard mopar small block bell housing to it?......"
On another site I frequent there was a guy who did this....he was a machinest by trade. As I recall there was a ton of hours involved making pretty impractical $ wise if you needed to farm the work out.
Personally would just dig up a GM transmission spend the $400 for the adaptor and try to find an original flywheel if he doesn't already have ove....it will be cheaper in the long run.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold 1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold 1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears) under construction
[Re: Mike P]
#1196551
03/13/12 10:27 PM
03/13/12 10:27 PM
Posts: 2,415 Connecticut
Ron_M
Connecticut
IIRC the 331 we once owned had a plate adapter that mated it to a Cad-LaSalle gearbox. Wasn't the Cad-LaSalle the preferred choice of the early hot-rodders? BTW, our 331 ended up in England in a Allard
Common sense is a flower that does not grow in everybody's garden
[Re: savoy64]
#1196553
03/14/12 06:53 AM
03/14/12 06:53 AM
Posts: 1,376 NORTHERN CA
HUSTLESTUFF
NORTHERN CA
They make an adapter where you cut off the fron of a 727 and mate it to the adapter. I have one but bought second hand already done. Mike http://hothemiheads.com/images/25010.jpg
"Were in it to win it. Anything less will end up being..... A whole lot of fun doing!!" UNLAWFL RIP UN
[Re: HUSTLESTUFF]
#1196554
03/14/12 09:45 AM
03/14/12 09:45 AM
Moparnut426
Despite what you guys, most of you guys are saying. Im not asking you if this is a desierable 331, I know its not. Dont really care, its a freeking chopped cobbled together RAT ROD. Back on track. That adapter for the 727 might be the ticket if I can convince him of going to the auto. Hes dead set on a manual. So If I do some measurements, I could make a plate on the back of the extended block/bellhousing thats flat, and make it mate to an 833 if the spacing is correct. Thats an idea, and would be cheaper than hacking off the rear of the block. And the 331s without the extended bell are NOT EASY to find. 55 was the ONLY year for a 331 without it. http://www.hothemiheads.com/hemi_info/hemi_engine_id.htmlThat being said, The only reason this engine isnt running is there is 2 stuck valves, well they arent stuck that badly. I have them freed up. and it had 1 hole that was barely stuck. Im gonna take it down to the bare block for him, check it all out, check for any cracks, do a valve job on the heads, get a gasket set, and have it freshened up. It will be the ONLY engine I dont clean up really nice and paint cause he wants "patina" LOL Kasey
[Re: dogdays]
#1196560
03/14/12 01:27 PM
03/14/12 01:27 PM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
All this @#$% for no reason, just buy the @#$% adapter and stick a manual transmission on it! It's been being done since the '50s. It'll be cool, of course it won't make mondo power but an honest 250 hp in a 2000 lb rod will be plenty fast. I think your biggest problem will be finding a flywheel that attaches to the crank properly.
R.
... Best answer in the whole thread
