2 lbs oil pressure at hot idle, acceptable?
#1196181
03/13/12 03:05 AM
03/13/12 03:05 AM
Posts: 4,576 Sarcoxie, MO, USA
MoPar Jamie
Sarcoxie, MO, USA
OK guys,
Got tired of seeing the idiot light on the Van on and the gauge dropping to nothing at hot idle so I pulled the doghouse and attached a mechanical gauge and ran it to see what was going on.
Wee when I cold started it it was at 45 at idle, over 50 down the road. Once it warmed up then it dropped to TWO pounds of pressure at idle. You could watch the line getting clearer and clearer. Down the road hot (No overdrive, 3.55 gears) it runs around 30-35 at 65-70.
So it confirmed my suspicions, its getting very little pressure warmed up idling, in gear or out. At highway speed there is a roar coming from the engine but it still has that 30-35 lbs pressure. let up and it goes away.
Once its revved a little then it jumps back up to around 25-30 depending on RPM. I am running 10W40 oil.
So, is my pressures okay or am I in danger of grenading the motor anytime soon? I know they are low but I would like to limp it along till my other truck is running.
I also pulled the breather and inside the baffle it was all gunked up. Probably a pennzoil motor.
- MoPar Jamie
1972 Fury III 4dr 1986 D-150 LWB Royal SE
Re: 2 lbs oil pressure at hot idle, acceptable?
[Re: MoPar Jamie]
#1196182
03/13/12 03:09 AM
03/13/12 03:09 AM
Posts: 819 Eugene, Oregon
Secret Chimp
Eugene, Oregon
No no no no no no no nononononononono. 2 pounds isn't even a normal fuel pressure much less oil pressure.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
[Re: A57_RT ]
#1196184
03/13/12 03:22 AM
03/13/12 03:22 AM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
Only chevy small blocks will work with 2 psi... Try some thicker oil, 20w 50 next oil change and see if makes any difference.. An oil pump change may help as well. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: bobby66]
#1196190
03/13/12 10:35 AM
03/13/12 10:35 AM
Posts: 1,519 AZ
Mike P
AZ
Just a thought (I've seen it before) If it had a timing chain with the plastic gear go away and valve seals got hard and broke up, chances are the oil pump pickup could be plugged. You might get by just pulling the pan and cleaning the pickup screen.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold 1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold 1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears) under construction
[Re: Mike P]
#1196191
03/13/12 11:24 AM
03/13/12 11:24 AM
RapidRobert
drop the pan and change out the pickup screen & a hi vol pump if that dont do it then some 50 wt racing oil
[Re: Mr.Yuck]
#1196193
03/13/12 11:32 AM
03/13/12 11:32 AM
Posts: 16,619 Almost Heaven
B_Body_Bob
Master of nothing
Master of nothing
Almost Heaven
I had one like that, ran it for about a year in the garage while fixing misc other stuff. It always had good oil pressure even while hot. Then I took it for a test drive, and the oil gauge would drop to zero at stops. Pulled the engine, pulled it apart, found it had chewed up a bearing or two. Your motor's dead. Don't waste money on thicker oil, it won't help.
Everybody makes fun of a hillbilly until they need something fixed
[Re: peelerboy]
#1196195
03/13/12 12:48 PM
03/13/12 12:48 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
No, that pressure is not okay and yes, you are in danger of grenading the engine sometime soon.
I can't believe that the lifters aren't rattling at idle with that little pressure. ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: MoparforLife]
#1196196
03/13/12 12:55 PM
03/13/12 12:55 PM
Posts: 9,838 Detroit, Michigan, USA!
peelerboy
You and me both. ![](/ubbthreads/images/graemlins/shock.gif)
[Re: MoPar Jamie]
#1196200
03/13/12 01:18 PM
03/13/12 01:18 PM
Challenger 1
Cincinnati, Ohio
I have a 1983 International 4X4 truck with a 345 gas V-8 engine. It is a old ultities company truck with a 7.5 ton crane on it. I bought it about 15 years ago just for the crane and the truck came with it.(that's what the dealer told me) I figured I could rebuild the engine since I had rebuilt other International gas engines. This engine has no oil pressure at idle, as soon as you rev it 100-200rpm the gauge moves. This truck is geared real low and screams out on the road, hi rpms. It's still running with no work done to it now for over 15 yeras. No we don't drive it 8 hours a day, but we did for like 10 years. It mostly sit's nowadays but has never gave up and it has almost no oil pressure at idle. Now I did rebuild the trans twice and the transfer case once, but never the engine. lol ![](/ubbthreads/images/graemlins/tongue.gif) To the OP, I say drive it until it dies, it might be a long time from now? ![](/ubbthreads/images/graemlins/shruggy.gif)
