Re: MOST FLOW OUT OF A SET OF -1S
[Re: cudabin]
#1193653
03/11/12 01:27 PM
03/11/12 01:27 PM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
N/A my 557ci made 955hp (Methanol injection)w/ 345cc CNC'd -1's that flow 382 at .800 these are Jeff's from Modern's program.
Cam is .875" (less lash and deflection)so i am opening them up as far as reasonable ![](/ubbthreads/images/graemlins/biggrin.gif)
Car weighs 2,850 and at 4,000 foot DA ran 8.80's, but there is more left in the combo...
If you want more than that N/A you need a better head IMO.
Cheers,
Arnie
Arnie, Shift point? Trans? Have you ever looked at your combo, and thought, "Darn, I should have went with a better head", or are you happy??
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: MoparBilly]
#1193654
03/11/12 01:46 PM
03/11/12 01:46 PM
Posts: 903 Saskatchewan, Canada
cudabin
Was shifting at 7,400 rpm as peak HP came at 7,200rpm.
i did not get many passes last year due to transmission problems (727) and broken valve springs. just put a set of Victory 2.25" Titanium valves and PSI 1224 Dual damperless springs on the -1's and will try a higher shift point this year...
Happy with the -1's as my chassis and my budget can't really handle anymore power...
Bang for the buck, I don't think it is worthwhile to upgrade to a better head for my program.
Cheers,
Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...)
70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
