Re: MOST FLOW OUT OF A SET OF -1S
[Re: cudabin]
#1193653
03/11/12 01:27 PM
03/11/12 01:27 PM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
N/A my 557ci made 955hp (Methanol injection)w/ 345cc CNC'd -1's that flow 382 at .800 these are Jeff's from Modern's program.
Cam is .875" (less lash and deflection)so i am opening them up as far as reasonable
Car weighs 2,850 and at 4,000 foot DA ran 8.80's, but there is more left in the combo...
If you want more than that N/A you need a better head IMO.
Cheers,
Arnie
Arnie, Shift point? Trans? Have you ever looked at your combo, and thought, "Darn, I should have went with a better head", or are you happy??
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: MoparBilly]
#1193654
03/11/12 01:46 PM
03/11/12 01:46 PM
Posts: 903 Saskatchewan, Canada
cudabin
Was shifting at 7,400 rpm as peak HP came at 7,200rpm.
i did not get many passes last year due to transmission problems (727) and broken valve springs. just put a set of Victory 2.25" Titanium valves and PSI 1224 Dual damperless springs on the -1's and will try a higher shift point this year...
Happy with the -1's as my chassis and my budget can't really handle anymore power...
Bang for the buck, I don't think it is worthwhile to upgrade to a better head for my program.
Cheers,
Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...)
70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
