71 Satellite dash #1193221
03/08/12 01:03 AM
03/08/12 01:03 AM
Seattle, WA.
E
edp Offline OP
edp  Offline OP
E
Seattle, WA.
extra holes on bottom of dash - are they meant for anything in particular?
what are the rectangular holes for?
the rubber bumpers in the glove box & ash tray - are they available?
Other questions - is this a wiring chase or perhaps for a AC or heater hose?
How does the glove box knob come off?
Anyone need an original speaker
what does this attach too - firewall??
Going to start the body work on the dash & get it painted - was satin black a standard dash color ? I have black panels & white bucket seats, probably use a white/off white headliner but also wondered about stock headliner colors too, anyone know?
Who makes aftermarket headliners?
Yeah I know,lots of questions - thanks for the help, much appreciated!
evan
Re: 71 Satellite dash [Re: edp] #1193222
03/08/12 01:50 AM
03/08/12 01:50 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Heres a pic showing the harness channel and the radio brace. 2 items you asked about.
Holes under the dash. On the drivers side is 3 set of 2 angled holes. Those are for the accessory switches. Rear defrost, A/G hood, ect. Under the ash tray are two pairs of holes for the vent cables. Your's looks a little messed up.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: 71 Satellite dash [Re: moparmarks] #1193223
03/08/12 01:58 AM
03/08/12 01:58 AM
moparmarks Offline
moparmarks  Offline
Also for the switches.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: 71 Satellite dash [Re: moparmarks] #1193224
03/08/12 02:42 AM
03/08/12 02:42 AM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
Actually, I think the rectangular holes are for the light from the bulbs on the underdash switches (A/G, rear defrost, etc.) to shine on the switch bezels/labels/knobs.
Re: 71 Satellite dash [Re: edp] #1193225
03/08/12 03:00 AM
03/08/12 03:00 AM
Seattle, WA.
E
edp Offline OP
edp  Offline OP
E
Seattle, WA.
hey thanks guys,a pic's worth a 1000 words sometimes. Didin't even dawn on me that that could be a radio bracket! Anybody got pic's of the switches & lights your talking about for under the dash?
Anyone have any idea's on the other stuff - headliner, dash colors, etc...?
Oh yeah, am I dreaming to want a tic-toc tach instead of my clock?
Thx!
Re: 71 Satellite dash [Re: edp] #1193226
03/08/12 03:12 AM
03/08/12 03:12 AM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
I don't, but perhaps 72RoadRunnerGTX may chime in - he's got pictures of durn near everything on his...
Mine's all one color (dark green), so can't say other than dash should probably be black if the interior is black and white. Others here have two-tone interiors, so they may chime in...
Thx!
71-74 clock/tach hole only can do a clock OR a tach. I don't think tic-toc-tach was available for our cars - think that was 68-70 only. Unless aftermarket has come up with something.
Re: 71 Satellite dash [Re: MoparMarq] #1193227
03/08/12 03:31 AM
03/08/12 03:31 AM
Shoreline, Washington
72roadrunnergtx Offline
You rang? Here's an Air Grabber switch for that dash with light fixture that shines through the rectangular hole to illuminate the switch bezel.
Re: 71 Satellite dash [Re: edp] #1193228
03/08/12 10:54 AM
03/08/12 10:54 AM
IL
71383beep Offline
71383beep  Offline
IL
Thx!
Well for 71 to 74 if you already have a clock dash you can switch it too a tach, but they did not make a tic-toch tach. Its one or the other unfortunately. At least you have a dash with the clock. They had a bother kind that had a combination oil and water gauge pod and those dashes do not readily take the optional tach or clock.
'73 GK6 Challenger Rallye - 340 4-Speed
Re: 71 Satellite dash [Re: 71383beep] #1193229
03/08/12 07:29 PM
03/08/12 07:29 PM
Seattle, WA.
E
edp Offline OP
edp  Offline OP
E
Seattle, WA.
why did some dashes have the AC/heat vent on the drivers side & some not. 72 RR's has the vent & I'm planning on running an AC setup, probably stock as I have the AC heater box but have considered the aftermarket ones that retro in as well.
At least know I know I cant have the tic - toc, I'll switch to a tach. I presume I can buy a repop one ?
Thx!
Re: 71 Satellite dash [Re: edp] #1193230
03/08/12 10:11 PM
03/08/12 10:11 PM
moparmarks Offline
moparmarks  Offline
Theres an A/C dash frame and a non-A/C frame. Difference is the drivers side vent for A/C.
Reproduction tachs are out there.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: 71 Satellite dash [Re: moparmarks] #1193231
03/09/12 01:18 AM
03/09/12 01:18 AM
Seattle, WA.
E
edp Offline OP
edp  Offline OP
E
Seattle, WA.
is the drivers side vent the only difference between an AC dash & a non AC dash or are there other subtleties I should be aware of?
I do have a vent for the drivers side, I could fab the hole in if its the only difference but it'd be nice to have a oic of an AC dash frame as well.
thanks ,Evan
Re: 71 Satellite dash [Re: edp] #1193232
03/09/12 01:32 AM
03/09/12 01:32 AM
I have an extra A/C dash frame hanging around If you need one.
1972 Road Runner GTX 440 6bbl 5-speed
[img]http://72rrgtx.com/carpics/bucket/DSC06730r-1.jpg[/img]
Re: 71 Satellite dash [Re: 72roadrunnergtx] #1193233
03/09/12 12:03 PM
03/09/12 12:03 PM
North East Missouri
E
express Offline
express  Offline
E
North East Missouri
Glove box lock. On inside of door you should see a small slot in the lock housing. Look in this slot, you should see a wafer, press in with a paper clip & pull cylinder out. May need to trip latch so cylinder will turn so that you can see it. If you have key insert it first, if not you may need to push in on each wafer one at a time.
cny25421@centurytel.net 70 Duster Turbo Charged 79 Lil Red Express Bonded Locksmith
Re: 71 Satellite dash [Re: edp] #1193234
03/10/12 12:54 PM
03/10/12 12:54 PM
Seattle, WA.
E
edp Offline OP
edp  Offline OP
E
Seattle, WA.
Hi Doug, I sent you a PM.
Thanks, Evan
Re: 71 Satellite dash [Re: edp] #1193235
03/10/12 04:51 PM
03/10/12 04:51 PM
Central New York
bfury Offline
bfury  Offline
Central New York
Another question if I can hop on. Does anyone know the location of the screws to take the dash pad off?
No Stock
Re: 71 Satellite dash [Re: bfury] #1193236
03/14/12 12:42 AM
03/14/12 12:42 AM
Seattle, WA.
E
edp Offline OP
edp  Offline OP
E
Seattle, WA.
Hi Doug (72Roadrunner) - I sent you a PM about the dash & misc=, not sure if you've seen it yet or not. Please give me a shout when you get a chance - thanks a lot!
Hi other Doug (Express) here's some pic's of the glove box door & lock that I'm trying to get the lock cylinder out of, maybe you can show me something obvious I'm missing!
and here's some updated pic's of the dash after a little hammer & dolly work, welding, grinding, filler & sanding down. I plan on shooting it in epoxy then topping with SEM hot rod black.
Thanks all!
Re: 71 Satellite dash [Re: edp] #1193237
03/14/12 01:55 AM
03/14/12 01:55 AM
Evan,
Do you have the key for the lock? The correct procedure to remove the lock cylinder requires having the key and the latch in the lock position, key removed. You should then see a spring loaded tang through the small square hole in the bottom of the hatch housing. Depress the tang with a small tool of some kind and insert the key; lock cylinder should then slide out. Without the key there is another small square hole 90 degrees away, under one of the mounting tabs and difficult to get to with the latch in the door, would have to depress the retaining tab and the tumblers one at a time to get the cylinder out intact.
Check your pm, talk soon
Re: 71 Satellite dash [Re: 72roadrunnergtx] #1193238
03/14/12 10:58 AM
03/14/12 10:58 AM
North East Missouri
E
express Offline
express  Offline
E
North East Missouri
I agree with the other Doug Great minds think alike. Sometimes they will stick, get your finger nails behind the thumb turn & pull when you push in the retainer.+
Here is one of my favorite tools for retainers.
Re: 71 Satellite dash [Re: express] #1193239
03/14/12 11:09 AM
03/14/12 11:09 AM
DELAWARE
bee71mopar Offline
bee71mopar  Offline
DELAWARE
Also on the bottom of the dash, 4 of the holes could be used for the fresh air cables.
Good job on filling those holes on the bottom.
Re: 71 Satellite dash [Re: bee71mopar] #1193240
03/14/12 02:20 PM
03/14/12 02:20 PM
Oakville, Ontario, Canada
CDN72SE Offline
CDN72SE  Offline
Three possibilities for the underdash holes.
Re: 71 Satellite dash [Re: CDN72SE] #1193241
03/14/12 02:24 PM
03/14/12 02:24 PM
CDN72SE Offline
CDN72SE  Offline
The rubber bumpers in the glove box & ash tray you can find at R/T Specialties: http://www.rtspecialties.net/ just do a searh on glove box or ash tray. They may be available at other places as well.
Re: 71 Satellite dash [Re: CDN72SE] #1193242
03/14/12 05:57 PM
03/14/12 05:57 PM
Seattle, WA.
E
edp Offline OP
edp  Offline OP
E
Seattle, WA.
Thanks all! I try the lock method again - I do have the key & have tried it already both in & out, I'll get it it's just annoying something so simple can be a pain in the a**.
I think I have one of those tools somewhere.......
I'll post some pic's of the dash when its painted.
