Re: Is this an engine builder's Trick?
[Re: Labratt]
#1192345
03/08/12 01:23 PM
03/08/12 01:23 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
Makes perfect sense to me! I agree 100% with Mike's(Sport440) assessment of the drilled hole acting like an EDM solid lifter! The oil dripping through the drilled holes is aimed more directly onto the cam lobes...instead of just a random over-flow!
Yep.......I also drilled one at the rear of the valley to oil the distributor drive gear ( R-3 ) just because it seemed like a good idea. On paper , it will allow oil that would normally be stuck up there back to the pan under acceleration too. At worst , it is harmless unless you leave a sharp edge / stress riser for a crack to start at. But it seems like a good idea.
[Re: DusterMan]
#1192348
03/08/12 05:49 PM
03/08/12 05:49 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
We used to drill the valley for oil drain back,but with the advent of better oil systems we find it unnecessary,heck we used to polish the lifter valley before we knew better.
Wow memories. Now I really feel retired and old. Of course I still smooth out rough castings everywhere. Makes it look purrty.
At my age memories out number any new ideas or thoughts.
[Re: GwaiiEagle]
#1192350
03/09/12 11:24 AM
03/09/12 11:24 AM
Posts: 75,092 A Banana Republic near you.
JohnRR
I have thought of drilling those holes because any old engine I have taken apart has sludge built up in everyone of those depression because there is always some amount of oil that never gets out of that area .
Back in 03 Dulchic added a series of formed alum shields under the cam to redirect the oil to the bulkheads so as to keep the oil from draining directly down on the rotating assembly ... I ASSuME ??? ... granted this was for a DYNO only competition so maybe it's fine for something that has limited use and life ?
I've had thoughts of adding the shield to a couple of my builds , my question is does the cam need the spray of oil be flung off the rotating assembly to live ?
It seems it would be also a good idea on an engine using a roller cam to keep the needles from a roller failure out of the bottom end ?
[Re: JohnRR]
#1192352
03/09/12 02:13 PM
03/09/12 02:13 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I have thought of drilling those holes because any old engine I have taken apart has sludge built up in everyone of those depression because there is always some amount oof oil that never gets out of that area .
With the advent of the new roller lifters that use the edm oil hole to oil the roller/axle you really dont need any added oil... even if not using a roller lifter there is still a fair amount of oil that gets by the lifter and the lifter bore thats drips down there... I am using the edm rollers so hopefully I can have the engine idle at a lower rpm(street rod)
[Re: MR_P_BODY]
#1192353
03/09/12 09:27 PM
03/09/12 09:27 PM
Posts: 1,496 Sask, Can.
72demon416
Sask, Can.
Not drilling them provides a place for some of the trash from my broken rocker arm needle bearings to collect! Better than running the stuff through the oil pump!
I still glue screen over ALL the openings on the top
That's a good idea What do you use for screen and glue?
[Re: 72demon416]
#1192354
03/09/12 09:33 PM
03/09/12 09:33 PM
MR_P_BODY
I use door screen and JB Weld to glue it in.... not the plastic screen stuff
