Re: any gains going from 4.10 to a 4.30 gear
[Re: mopar dave]
#1188951
03/04/12 05:33 PM
03/04/12 05:33 PM
Posts: 17,928 Akron, Ohio
ProSport
Akron, Ohio
I went from 4.30's to 4.56's in my old 9 second DartSport(at the time of the gear change it was in the 10.20's), the trap RPM went up a couple hundred RPM's but the ET didn't change at all, should have stayed with the 4.30's. This was a 451 low deck, Eddy heads, and 590 purpleshaft cam.
[Re: Otherlane]
#1188956
03/09/12 10:50 AM
03/09/12 10:50 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I running a w8 motor.At 8000 rpms it seem like it was out of steam
What CI is it and how big is the carb... 7400 for a W-8 seems on the low side for a W-8 head unless its big CI ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1188957
03/11/12 09:14 AM
03/11/12 09:14 AM
Posts: 830 east coast
Otherlane
east coast
428 in with a 1100 carb
[Re: Otherlane]
#1188958
03/11/12 10:41 AM
03/11/12 10:41 AM
MR_P_BODY
7400 isnt that bad with 428ci... you could use less gear and might see a improvement ![](/ubbthreads/images/graemlins/wave.gif)
[Re: mopar dave]
#1188960
03/11/12 05:01 PM
03/11/12 05:01 PM
Posts: 3,210 robin hood country
deaks
robin hood country
I run 4.56 gears in my 440 and i thought about going to 4.30's to keep the rpm down. I've decided to throw my $500 at a set of Afcos instead. Point being, you might be better to think where the money could be better spent. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
