Re: Jegs windage tray/gasket with stock oil pan [Re: moparmike1] #1188298
03/05/12 12:16 AM
03/05/12 12:16 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
After looking at the one my buddy got it looks to me like it would work great if you have an aluminum oil pan with a nice flat surface such as the block is. I do agree it looks like it wont seal to good to a normal stock type pan. The stock pan needs a gasket that compresses a tad to fill in the pan rail. The problem with this is its hard plastic with the rubber seal made in it but that seal will not hit all the pan rail enough to me and will leak. If I had to use it I would put a small bead of the gray Mopar rtv sealer on both sides and hope it seals. Ron
Re: Jegs windage tray/gasket with stock oil pan [Re: 383man] #1188299
03/13/12 08:22 PM
03/13/12 08:22 PM
Temecula, CA
Dukes69 Offline OP
Dukes69  Offline OP
Temecula, CA
Well to cap it off, not only does it not fit for squat, the rods on a stock stroke crank hit the windage tray.
I'm done with it. Great idea, HORRIBLE execution. At least I'll get most of my money back when I ship it back.
Mancini is tomorrow. I hope they care a little more than Jegs.
-Chris
Re: Jegs windage tray/gasket with stock oil pan [Re: Dukes69] #1188300
03/13/12 08:44 PM
03/13/12 08:44 PM
New State
kidmopar Offline
kidmopar  Offline
New State
-Chris
You guys have all talked me out of EVEN trying this thing. I'm going to stick with the metal tray & 2-gaskets!
Re: Jegs windage tray/gasket with stock oil pan [Re: kidmopar] #1188301
03/13/12 08:51 PM
03/13/12 08:51 PM
Temecula, CA
Dukes69 Offline OP
Dukes69  Offline OP
Temecula, CA
That's what we did. All the fancy junk got replaced with stock stuff and no leaks.
Re: Jegs windage tray/gasket with stock oil pan [Re: CR8CRSHR] #1188302
03/13/12 09:12 PM
03/13/12 09:12 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
I got mine from Summit. part number is P4120998 it's a Mopar performence peice. Fit my stock pan perfect. Doesn't leak. Good old fashion gaskets.
Re: Jegs windage tray/gasket with stock oil pan [Re: Dougsmopars] #1188303
03/13/12 11:06 PM
03/13/12 11:06 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I bought a billet rear main seal and retainer from Hughes Eng and it has worked flawless. No leaks at all. Ron
