Re: Who's got the recipe for a hot running 383.
[Re: JohnRR]
#1187851
03/29/12 12:30 AM
03/29/12 12:30 AM
Posts: 559 Idaho
LaRoy Engines
Idaho
For your consideration. We pulled this outta the junk pile and built it.
+.030" 383, stock forged crank, stock rods & bolts, cast pistons flycut with die grinder, 8:1 compression. Ported 906 heads. eBay used Crane Gold Race 1.5 rockers. Used cup and ball pushrods recut to length. Hughs solid flat tappet, 242/248, .543"/.563" Edelbrock Victor 383 intake. The old trusty 950 cfm 4150 Quick Fuel.
RPM.......LB-FT........HP
3600......348.........239 4000......341.........260 4500......369.........316 5000......371.........354 5500......412.........432 5600......426*.......454 6000......414.........473 6500......398.........493 6600......401.........504*
Did it get installed in anything, if so what did it run and what did it weigh ???
Nope, we built it to test the heads and some intake manifolds, the engine got split up.
The short block got a hydraulic roller (the last one I will EVER use) and went into the grandson's 4x4 pickup.
The heads went onto the 451 of the "WarRock Warlock" pickup (big, black and 40" tires). The last time at MATS it ran 12.90 at 100ert-n-sumthin. He is still tryin' to figure out how hard to launch it and how to get it to hook up.
[Re: moparmojo]
#1187853
03/29/12 11:49 PM
03/29/12 11:49 PM
Posts: 1,285 Pacific NW USA
CompSyn
Pacific NW USA
For a 383 stroker using 440 parts, can I use the same pistons or do I need stroker pistons with shorter skirts? Im just wondering the cost to build a budget stroker with parts I may already have vs a stock 383 build. Unlike other motors I have built before, I would finally like to succeed in a budget build for once and not go broke. My goal is to get the Charger running this year. It has sat for the last decade since I got it. Time to finally do something with it. Once done I can figure out what to do about the body.
You are correct that you'll need shorter skirt pistons. And since you're talking about a 383/432 type stroker, you'll be looking to forged pistons from Ross or Diamond which will make for not a budget build.
[Re: CompSyn]
#1187854
03/30/12 10:54 AM
03/30/12 10:54 AM
Posts: 75,004 U.S.S.A.
JohnRR
U.S.S.A.
what he said , the 383 is the red headed stepchild of big block mopars .
I tried for 3 years to sell a set of diamond .030 pistons for a 383 based stroker , at a loss as I usually do some people wanted me to give them the pistons for free and pay the shipping ... moparts is full of the cheapest [censored] in the universe ... someone finally realized what a smoking deal they were and bought them a month or so ago.
Diamond makes a piston that will work with the stock 383 rods, you can use a 440 crank and have the mains and counterweights cut to fit the 383 block, you'll have to buy $$ pistons.
Another deal was the 383 that was being sold in the parts section, the pistons and the rods in the ad cost me originally a lot more than what I sold them to him , I bought them back because I realized what a good deal they were. Speed pro pistons weight matched, refurbed stock rods with wavelock bolts and a set of plasma moly ductile rings . Dan at Performance Only did the rods , they were a work of art on a set of rods I picked thru 3 or 4 sets to get the best ones.
[Re: 65rbdodge]
#1187855
03/30/12 12:26 PM
03/30/12 12:26 PM
Posts: 3,916 usa
lewtot184
usa
i have a 400 in my dart which is just a 383 with a bigger bore. i think it runs really good, here is the combo-
KB hyper pistons @ 0 deck eddy heads 84cc milled to 74cc comp cams roller rockers eddy performer RPM intake holley 750 street hp comp cams XE274 cam stock forged crank from a 383 stock rods/oil pan headers and 2.5: duals w/x-pipe 355 gears w/locker
this would probably make a nice dependable street build.
[Re: JohnRR]
#1187856
03/30/12 12:27 PM
03/30/12 12:27 PM
Posts: 3,916 usa
lewtot184
usa
Did you have to notch the top of the bores for those size valves?
One doesn't have to , but notching the bore on the exhaust side would be a good idea, the Max wedge had 1.88 exh valves and they notched the bore.
i used to notch both sides on the 4.25 bore to match the combustion chamber.
[Re: lewtot184]
#1187857
03/30/12 12:34 PM
03/30/12 12:34 PM
Posts: 3,916 usa
lewtot184
usa
back in the day i had a '68 383 4spd road runner with 4.10 gears. with a dp4b intake, crower 201hj cam (228@.050-.480 lift, no longer available), hooker 1 3/4 headers, 780 holley, probably 3850lbs with me in it, stock pistons and heads; it would tickle 12.90's. drove it everyday, it was the only car i had. with today's modern heads and cam profiles this should be easy to duplicate. just one biggie to keep in mind, DON'T OVERCAM! evrytime i went to more cam the car slowed down.
[Re: RemCharger]
#1187860
04/03/12 01:32 PM
04/03/12 01:32 PM
JohnRR
U.S.S.A.
Money is better spent on heads.
[Re: moparmojo]
#1187861
04/03/12 01:34 PM
04/03/12 01:34 PM
JohnRR
U.S.S.A.
Well just out of curiosity, I may just price out what it would cost to "stroke it". But even if I just did a nice standard rebuild with a few hand picked parts, I could still be happy. Anything to get the beast back on the street would be good. I'll price it both ways, but like most of us I always want a bit more. I'd like to stay with stock heads and valve train to save money, as long as they are in good shape.
then the cheapest route is the just do a 440 , you can stroke out the 383 , spend the $$$ and still have nothing better than a stock 440 because of your head choice .
[Re: JohnRR]
#1187862
04/03/12 03:27 PM
04/03/12 03:27 PM
Posts: 12,861 Gloucester,VA STOP MOVING HERE
RangerDan440
the OP said he wanted to keep his 383
theres an article in this months Mopar Muscle-a simple 906 headed 383 with a mild Comp Cam (~.500) a dual plane intake and a 750 carb and a good tuning will put a 383 into the 425 HP/500 ft/lbs neighborhood. Thats plenty for a fun street driven musclecar. $3K more or less depending on your local machine shop.
It doesnt take a lot of high dollar parts to get power out of a big block.
68 Valiant 408 69 Charger 318 69 Cougar 351W 70 Torino GT 351C 71 Country Squire 351W 71 Road Runner 440+6 71 Satellite sedan 318 73 Duster 318 73 Challenger 383 77 Grand Prix 455 83 Malibu 9C1 383 84 Delta 88 403 87 Grand National 96 Ram 360 09 Crown Vic 10 Challenger R/T M6 15 Challenger Hellcat M6
[Re: RangerDan440]
#1187863
04/03/12 03:36 PM
04/03/12 03:36 PM
JohnRR
U.S.S.A.
the OP said he wanted to keep his 383 Quote:
I was responding to this ...
It doesn't take a lot of high dollar parts to get power out of a big block.
I'll have to check that one out , I'm doing an on the cheap rebuild of a 383 for a friends Road Runner and that may be the ticket for what he wants .
[Re: JohnRR]
#1187864
04/03/12 03:39 PM
04/03/12 03:39 PM
moparpollack
Lil Herman
Lil Herman
85086
You can do mine also as it was pulled out of the car this weekend.
Now all I have to do is find choose a slow or fast shop to do the work.
[Re: RangerDan440]
#1187866
04/03/12 06:09 PM
04/03/12 06:09 PM
JohnRR
U.S.S.A.
I wasnt singling you out Johnny
My local machine shop just did my Pontiac 400-$2200 covered a sonic check, .030 overbore, balancing and cylinder head cleanup and they even assembled it for me. Theres no reason a 383 like the one in MM couldnt be done for under $3K
I need to move where labor is cheaper, I'm not sure what this one is going to cost but the budget is 3k.
I also have a stock bore 383 HP that I'm going to dingle ball hone and put in fresh rings and bearings type of rebuild to throw in my superbee for now .
