return reg. #1186251
02/26/12 09:11 AM
02/26/12 09:11 AM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
what is the advantage of a return style reg. and when would it be necesary?
Re: return reg. [Re: bonefish] #1186252
02/26/12 09:50 AM
02/26/12 09:50 AM
Northern OH
rapom Offline
rapom  Offline
Northern OH
Fuel will be cooler in a hot engine compartment.
Fuel pump will run cooler, quieter, and last longer.
I think it would be more needed if you plan on doing a lot more street driving than drag racing.
Re: return reg. [Re: bonefish] #1186253
02/26/12 03:21 PM
02/26/12 03:21 PM
Carson City, Nevada
RobbMc Offline
RobbMc  Offline
Carson City, Nevada
A return or bypass regulator has a lot of advantages over a dead-head regulator but is only absolutely necessary if using a pump that does not have a built-in pressure limiting device (such as most pumps designed for fuel injection).
This regulator can be used as a dead-head or as a return regulator:
http://www.robbmcperformance.com/products/regulator.html
Designing a better mouse trap always seems to lead to the evolution of smarter mice. www.robbmcperformance.com
