Mopar Prop Valves / Distribution Blocks
#1185688
02/25/12 05:05 AM
02/25/12 05:05 AM
Posts: 4,920 Joplin, MO USA
Robbins
Joplin, MO USA
Please educate me here. I've got this prop valve off of a disc/drum 74 A-body car. I'm running four disc brakes on my 64 Valiant now. Things haven't been right from the beginning. One thing I found was that the master was leaking from the back. Got a new one from Dr. Diff. But the prop valve is confusing me. Inline tube shows that on some cars the five port valve like mine was some times put on cars by itself and on some it had another one added to it. So I'm wondering if I can use it or not? http://inlinetube.com/Prop%20Valves/pro_valves.htmDown the page some for Mopar stuff. http://www.summitracing.com/parts/SUM-G3905/I've got this that I'm going to put on also.
Moparlee
Re: Mopar Prop Valves / Distribution Blocks
[Re: DoctorDiff]
#1185696
02/25/12 08:03 PM
02/25/12 08:03 PM
Robbins
Joplin, MO USA
Cass, so with this work then?
They're showing a block that is five port (darn near like the BLK246 (which is the one from the 74 car) that looks like they are saying that it's just distribution block. Which is BLK244 from Inline tube. So if I use this one then it mounts the same and the lines aren't really going to need to be different.
Moparlee
