Page 4 of 4 1 2 3 4
Re: Mopar race intake manifolds for smallblocks? [Re: Streetwize] #1185281
03/04/12 02:17 PM
03/04/12 02:17 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Good pics My M1 is very similar in mods to your victor 340, any chance of a side x side of A victor next to a M1 small port
Re: Mopar race intake manifolds for smallblocks? [Re: emarine01] #1185282
03/04/12 09:25 PM
03/04/12 09:25 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
I used to have an M-1 with the carburetor pad welded up and
milled for the 4150 opening. It had a little porting but, I don't
think I have any pictures of the inside. I like the Victor 340,
ported for almost everything that uses an OEM style head.
At least with big RPM 340s and 525+ HP strokers.
Here's a stock SB M-1.
Re: Mopar race intake manifolds for smallblocks? [Re: S/ST 3040] #1185283
03/10/12 06:37 PM
03/10/12 06:37 PM
S/ST 3040 Offline
S/ST 3040  Offline
I ran on to this as I was looking for something else and thought
it was interesting. Ported W-5 head flow with different intake
manifold tested on the flow bench. Take it for whatever it's worth.
Copied and pasted from a 6 year old PM:
4.155" Bore....................W/INDY.....Small Port M-1........Large Port M-1
.100-66.3.........................66.5.............66.0......................66.5
.200-139.2.......................140.0............136.0....................136.1
.300-207.3.......................206.8............193.0....................202.0
.400-258.1.......................258.7............244.0....................248.7
.500-293.6.......................292.8............257.3....................276.7
.550-295.6.......................297.0............263.5....................279.3
Both Mopar manifolds are completely unmodified.
Large Port has the 4150 carburetor flange.
Re: Mopar race intake manifolds for smallblocks? [Re: Streetwize] #1185284
03/10/12 07:28 PM
03/10/12 07:28 PM
S/ST 3040 Offline
S/ST 3040  Offline
............also what is the hole bored between the runner pairs in front of the plenum?
I put that in there to run the sending unit wire to the thermostat housing.
Just to keep it tucked out of the way. Plus, that was a chunk of aluminum,
the size of a quarter, I didn't have to drag down the track.
Re: Mopar race intake manifolds for smallblocks? [Re: S/ST 3040] #1185285
03/26/12 04:13 PM
03/26/12 04:13 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Vic... was the Indy ported or just port matched to fit the W5s?
Re: Mopar race intake manifolds for smallblocks? [Re: emarine01] #1185286
03/26/12 06:42 PM
03/26/12 06:42 PM
S/ST 3040 Offline
S/ST 3040  Offline
Welded, ported and converted to 4500 top.
Re: Mopar race intake manifolds for smallblocks? [Re: S/ST 3040] #1185287
03/26/12 06:44 PM
03/26/12 06:44 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Thankx Vic, good info for the files
Re: Mopar race intake manifolds for smallblocks? [Re: emarine01] #1185288
03/27/12 12:50 AM
03/27/12 12:50 AM
Sask, Can.
72demon416 Offline
72demon416  Offline
Sask, Can.
I went a little different direction then everybody else with my W5 Indy that Ryan converted.
https://board.moparts.org/ubbthreads/show...&PHPSESSID=
Re: Mopar race intake manifolds for smallblocks? [Re: S/ST 3040] #1185289
03/28/12 10:48 AM
03/28/12 10:48 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Any info on what the Indy flows stock OTB?
Re: Mopar race intake manifolds for smallblocks? [Re: emarine01] #1185290
03/28/12 01:22 PM
03/28/12 01:22 PM
S/ST 3040 Offline
S/ST 3040  Offline
I didn't have an OOTB INDY at the time I did the testing but, suspect it
would have been better than either M-1.
Page 4 of 4 1 2 3 4
