All else being equal........
#1184780
02/23/12 02:01 PM
02/23/12 02:01 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
What effect might be seen by moving weight lower and rearward? The Charger as it is has a tendency towards oversteer. To quickly recap the stats: '70 Charger, 440 block with aluminum heads, 727, 8 3/4 axle. 1" T bars, 1 1/8" front sway bar, MP leaf springs, 7/8" rear sway bar, KYB shocks, welded frame connectors and torque boxes. My previous understanding is that in most cases, moving weight away from the front toward the rear reduces UNdersteer. I'd planned on relocating the battery to the trunk, but at this point, I need LESS understeer like I need a 3rd leg. The frame connectors and torque boxes added about 48 lbs to the car, luckily the weight was low and in the center. The relocation of the battery can wait until I sort out the balance of the car. I'm going to run the car without the rear bar to see how it feels. One option is to use a 3/4" bar with rubber end link bushings. Please let me know what you think. Thanks, Greg.
Re: All else being equal........
[Re: 72Swinger]
#1184784
02/23/12 02:36 PM
02/23/12 02:36 PM
Kern Dog
Granite Bay CA
295 45-18 on a 10 inch rim......... I SAW your specs though.... pretty impressive! To fit a wider tire, I'd need to modify the outer wheel tubs. The design is such that they do NOT follow the quarter panel straight up. Instead, the tubs sit inboard of the quarter by 3 inches before they go vertical. This makes it impossible to push the tires flush to the wheel arch at my current ride height.
[Re: 72Swinger]
#1184785
02/23/12 02:36 PM
02/23/12 02:36 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Or more back tire
Edit, Ok there is more room but playing with the bar still is the better option...
I think he's about maxed that option out...He could go with less front tire but I don't think that's really an option he wants to explore either... Besides, new tires cost more than a new bar.... Fact is I'd consider going with a 5/8" rear bar but with adjustable end link mounts so it could be tuned..... A 5/8" bar with the effective lever shortened can act stiffer than his current 7/8" bar but with long arms is could be softened to the point that the car understeers..
[Re: Kern Dog]
#1184786
02/23/12 03:04 PM
02/23/12 03:04 PM
Posts: 1,376 NORTHERN CA
HUSTLESTUFF
NORTHERN CA
When I took my car to Willow Springs last year it was very neutral to me and the instructor. I didn't run a rear bar because the hardware was at the powder coat shop. Try unhooking the bar completely and see how it drives. Mike
"Were in it to win it. Anything less will end up being..... A whole lot of fun doing!!" UNLAWFL RIP UN
[Re: HUSTLESTUFF]
#1184789
02/23/12 05:55 PM
02/23/12 05:55 PM
Posts: 27,471 So Cal
autoxcuda
So Cal
Experiment with what you have.
Using an adjustable rear sway bar bar is very helpful in this respect.
Mike, what that Bob Reed that drove you car and didn't want you to put a rear bar on it?
[Re: Kern Dog]
#1184792
02/24/12 01:11 AM
02/24/12 01:11 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Bigger t-bars would probably tighten her up dood.
Mopar to the bone!!!
[Re: HUSTLESTUFF]
#1184793
02/24/12 03:57 AM
02/24/12 03:57 AM
Kern Dog
Granite Bay CA
I removed the 7/8" rear bar and laid it on the workbench to compare its shape against a spare 3/4" bar of unknown origin. They both had the same light gold anodized finish common with Addco bars. The bigger bar had a lever length of 9 1/4" from the end link eyelet to just past the 90 degree bend. The smaller bar had a 8 1/4" lever. Correct me if my logic is flawed here, but wouldn't this mean that the smaller bar would be nearly as effective as the larger one? Example: An even SHORTER lever on the smaller bar may actually be as effective as a larger bar with a longer lever? I went ahead and drove the car without any rear sway bar. I drove on the street, but was able to make a few 90 degree turns away from any traffic. There was more body roll, but the car also felt a little less "bound up" if that makes any sense. It handled more predictably and the rear only got loose under throttle. My guess is that the currect setup leaves a lot of room for improvement, but for now it feels better to drive on the street. I have a welded and gussetted K member I'll swap in after it is painted. I'm also planning on Bilstien shocks, but I have to generate some cash to pay for them. Thanks for the suggestions!
[Re: Kern Dog]
#1184794
02/24/12 01:01 PM
02/24/12 01:01 PM
Posts: 5,394 Pikes Peak Country
TC@HP2
Pikes Peak Country
This logic may be correct. With that particular arrangement, there may only be a slight difference between the bars, assuming the mounting positions on the axle and connection points on the frame are similar. You can only know if you check. On my car, the difference in rate between a .75" frame hung and a 1.0" axle hung bar is only 30#, despite the large difference in diameter.
Here is a link to a calculator you can use to figure out absolute bar rates: http://www.circletrack.com/car_racing_calculators/torsion_bar_rate_calculator/index.html
Here is another article to understand how it all translates to the tires, this is the front bar on an oval track car, but the pricipal is the same: http://www.circletrack.com/chassistech/ctrp_1004_sway_bar_rating_techniques/viewall.html
[Re: TC@HP2]
#1184795
02/24/12 02:26 PM
02/24/12 02:26 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
According to that calculator the bigger bar with the longer arms is still much stiffer than the smaller bar.
Try the smaller bar if you want to trade a litte cornering for the body roll control.
