Paint issues question? #1183531
02/21/12 05:32 PM
02/21/12 05:32 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
Ok, I have my 68 Charger in media blast right now. I am having a friend help me get the body work and paint completed.
My budget is super tight right now. I am stunned on how much paint has gone up in price. I have gotten 1 gallon of DP90LF primer and 1 gallon of 5 star 2K primer which cost me $503.00 including a gallon of wax and grease remover.
I need to get the rest of my paint products. My friend wants me to us Omni, for which I received a quote of 1400.00. That included 2 gallons of 2K fill and sand, 2 gallons of base coat and 2 gallons of ppg 2021 clear.
I received an alternate quote for Nason products, it was 800.00 for smiliar quantities of primer, base and clear.
I would like my fellow moparts members on helping me decide which products to use and why. I would perfer to use top of the line products but my budget will not allow it. Tim
Re: Paint issues question? [Re: astjp2] #1183532
02/21/12 05:44 PM
02/21/12 05:44 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
You do get what you pay for in paint. Nason is ok but the gloss you get with PPG top of the line clear is fantastic. Bite the bullet, use the best paint. Just like un protected casual sex..... the results last forever.
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: Paint issues question? [Re: MOPARMIKE69] #1183533
02/21/12 05:49 PM
02/21/12 05:49 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
Will the Omni base coat be ok with the 2021? He also wants to use Upol clear for the trunk and under hood, will that work also? Thanks Tim
Re: Paint issues question? [Re: astjp2] #1183534
02/21/12 07:06 PM
02/21/12 07:06 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I'm not sure about mixing brands?
but my advise is to just buy what you need at the time, don't buy it all at once. Things change, just buy the best you can afford only when your ready to use it.
Re: Paint issues question? [Re: Challenger 1] #1183535
02/21/12 08:03 PM
02/21/12 08:03 PM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
What ever you buy be sure not to cheat on Primer. Cheap primer will make your paint job junk!!!
Re: Paint issues question? [Re: astjp2] #1183536
02/21/12 08:50 PM
02/21/12 08:50 PM
Anywhere the British Secret Se...
Moonraker Offline
Moonraker  Offline
Paint crowds are like car crowds everyone is going to have their opinion PPG/Omni and Dupont/Nason both have good systems. I have used both brands but I'm more partial to Nason/Dupont brands, no particuliar reason I just know the guys down at that shop better and I have used it a it alot more. Really its just what I latched onto. I have went both ways cheap and expensive and have achieved great results both ways. If you ask me a paint job is more about doing good prep work and finish work more than anything, when you start cutting corners on that is when you ask for trouble. I have also mixed brands (as have many people I know) that had similiar paint systems and never had issues, be it primer base/clear, etc...
I have used Nason only on my last two full paint jobs and both turned out amazing. I was mixing using Nason bases with Dupont clears but Dupont is just getting to damn expensive. I have heard that some clears are better than others as far as UV resistance and some do "flow" or lay down a little better than others, but to me its not worth the extra expense, you can cut and buff most minor imperfections. Stuff I painted 5 or more years ago is just as glossy as the day I sprayed it and shows no signs of breaking down anytime soon. Its when you spray the clear to thin that you run into issues with it breaking down under the sun.
If your car is going to be a trailer queen and never see the blacktop then by all means use the most expensive stuff you can afford, but for a driver you wont be disappointed in the least to go the cheaper route.
Re: Paint issues question? [Re: Moonraker] #1183537
02/22/12 12:05 AM
02/22/12 12:05 AM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
Some of the cheaper/budget lines need more material to cover, so there's no real savings.
best of 11.24 at 119 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: Paint issues question? [Re: FurryStump] #1183538
02/22/12 11:48 AM
02/22/12 11:48 AM
California
moparbroz Offline
moparbroz  Offline
California
What about the Eastwood paint systems?
Hebrews 11:1
Re: Paint issues question? [Re: astjp2] #1183539
02/22/12 01:33 PM
02/22/12 01:33 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Yes I have used the OMNI line base and used the 2021 clear with great results. Using another cheaper clear under the hood and in the trunk could work if they don't react to each other. But I would not do it. I never take a chance on mixing brands.
69 Road Runner vert
69 GTX hard top
70 Hemi Cuda vert
Re: Paint issues question? [Re: MOPARMIKE69] #1183540
02/22/12 02:32 PM
02/22/12 02:32 PM
PEI Canada
chromedome426 Offline
PEI Canada
I have been using Nason products for 9 years and have been happy with the results for the money.
For example: I painted the deck truck for my salvage yard back in 2006 with Nason single stage urethane and it still looks great today. And this is a vehicle that is always out in the elements and hardley ever gets washed.
Re: Paint issues question? [Re: astjp2] #1183541
02/22/12 05:26 PM
02/22/12 05:26 PM
WI, USA
67dodge67 Offline
mopar addict
67dodge67  Offline
mopar addict
WI, USA
I've used both and have had good results. First Q for you is this, what type of gun are you using? I'm thinking 2 gallons of base and clear is a bit much using a hvlp. When I shot my 67 Coronet using a hvlp, I initially bought a gallon and 1/2 each. I have a little less than a quart left over of both. Primer, yes, I used about 2 gallons but that was thru a conventional gun, not my hvlp (wish I would have done it with one to save $$). The only thing for me is, I didn't paint the underside... perhaps you are which = 2 gallons then I used PPG and got good results; it's been since 2005 and it looks great. On the other hand, I've used Nason for "quick" jobs and the results came out better than expected. I guess it's up to you to figure out what you want to use, as well as what type of gun(s) you're using. Best of luck!
Re: Paint issues question? [Re: chromedome426] #1183542
02/22/12 05:29 PM
02/22/12 05:29 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Have you considered using Summit's kit? The limiting factor is the choice of colors but if you can find something you like then that wouldn't be a bad way to go.
When it comes to price, you have to consider the WHOLE package. By that I mean to what extent is the quality of the rest of the car. There's no point in putting top dollar paint on something that hasn't been given a full rotisserie restoration, new interior, etc.. And the paint job is only as good as the prep and the guy squirting it. To me "having a buddy do the job" says it all - unless that buddy happens to be a full time painter by trade, and even then, what kind of job does he do if he's not getting paid his full usual rate? Just sayin' ... !!
Re: Paint issues question? [Re: 67dodge67] #1183543
02/22/12 05:33 PM
02/22/12 05:33 PM
IL . usa
cjs69mope Offline
cjs69mope  Offline
IL . usa
There is nothing wrong with Nason paints i use chroma base and nason clear all the time on production paint work for regualar street cars .
If its a driver use nason if its a show winner i mean world of wheels type show not weak end cruise night show then use Chroma premere. I have seen cars that had crap single stage paint on them win shows at the local cruise night Depends on whos voteing
But you can have avery nice car with nason .
1969 Dodge Charger 1969 Dodge Superbee
Re: Paint issues question? [Re: Stanton] #1183544
02/22/12 06:31 PM
02/22/12 06:31 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
Its a lot easier to upgrade interior and details later then it is to strip the whole car down and repaint it because you cheaped out on paint and body work though.
Re: Paint issues question? [Re: AdamR] #1183545
02/22/12 07:02 PM
02/22/12 07:02 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
Its on the rotissori getting media blasted as we speak. I will have to wait for interior because I only had enough money for body and paint this year. I have had the car 20 years and never even put a battery in it. It is now time to get started. Tim
Re: Paint issues question? [Re: astjp2] #1183546
02/22/12 08:24 PM
02/22/12 08:24 PM
santa anna, Tx.
charles6970 Offline
charles6970  Offline
santa anna, Tx.
you don't need that much paint for 1 car.
Re: Paint issues question? [Re: charles6970] #1183547
02/22/12 11:13 PM
02/22/12 11:13 PM
Cincinnati, Ohio
Cincinnati, Ohio
I suggested to only buy what you need when your ready to use it. That way you get a better idea as you go a long what and how much your gonna need. It helps me have 2 paint stores nearby. Hopefully you got some thing close.
Re: Paint issues question? [Re: astjp2] #1183548
02/23/12 12:58 AM
02/23/12 12:58 AM
Jacksonville Florida
elitecustombody Offline
Sherwin Williams DP800 is around $130 a kit. I love this epoxy primer
http://www.sherwin-automotive.com/products/show_product.cfm?product=DP800
Matrix AG40 High-solids clear is around $190 . Been using it for about 15 years with amazing results and wouldn't use anything else
http://www.matrixsystem.com/products.php?t2=4
If you have Matrix available in your area,buy their base,awesome coverage at very affordable prices.Don't waste your money on watered down Omni or Nason.
Re: Paint issues question? [Re: elitecustombody] #1183549
02/23/12 01:33 AM
02/23/12 01:33 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
I havent used nason, but have used OMNI, I think the call it shop line now.
Anyone, I have to question the reason to use the inexpensive base coat (Omni) with one of the most expensive clears..PPG 2021 is the good stuff. And so is the PPG DP primers.
I like the Omni paint, but it is somewhat watered down or thinned compared to the PPG DBU stuff.
I will assume you are a hobby painter, so I am going to rcommend something like a Single stage PPG Concept paint or a simple Dupont Imron / Sherwin Williams equalivent.
Reason being, the fewer wet coats of paint on the car ,the fewer problems with dust, dirt , humidity and runs.
Clear paint is pretty challenging to spray.
Re: Paint issues question? [Re: astjp2] #1183550
02/23/12 02:57 AM
02/23/12 02:57 AM
Seattle, WA.
E
edp Offline
edp  Offline
E
Seattle, WA.
try both Pro Spray Base & SPI clear. I used both on my Datsun project & they're excellent. The support you'll get from both of these guys companies is fantastic. Kicks a** on the price of PPG & Dupont products. SPI epoxy is great stuff too, quite reasonable compared to PPG.
Quality is excellent.....and I dont work for them either.
Datsun
Ask for Chad
http://www.autorodtechnologies.com/Product_Lines.html
Ask for Barry
http://www.southernpolyurethanes.com/
Good luck!
Re: Paint issues question? [Re: elitecustombody] #1183551
02/23/12 11:30 PM
02/23/12 11:30 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
I found the Matrix dealer in my area, prices were fair so I think I am going to skip the Omni and Nason and get the Matrix MSB base coat and the AG40 clear. I get a lot more material and better coverage for the money. Thanks Stefan for your advice. Tim
Re: Paint issues question? [Re: astjp2] #1183552
02/24/12 10:24 AM
02/24/12 10:24 AM
No problem Tim,glad to help. It was good talking to you yesterday. By the way, what are the prices you got,I'll check with my supplier and see if you're getting a good deal or not.
