Re: well im now in the tunnel ram club- i have a question
[Re: shoebox]
#1183427
02/23/12 12:43 PM
02/23/12 12:43 PM
Posts: 10,034 Frostbitefalls MN (Rocky&Bullw...
gregsdart
the 1987 intake has a small port in it for some BB applications. I picked up a solid .15 by porting mine on a stroker that had ported 906 heads.
[Re: gregsdart]
#1183428
02/23/12 01:21 PM
02/23/12 01:21 PM
Posts: 808 mckinney texas
shoebox
mckinney texas
thats one of the reasons im going to run it. it doesnt look "too big" i think its going to kick butt on my milder combo!
[Re: Ari440]
#1183431
02/23/12 02:08 PM
02/23/12 02:08 PM
Posts: 684 St. Charles, MO.
Slingshot383
St. Charles, MO.
I ran a pair of 750's, converted them to 4-corner idle circuits, and Dominator style secondary throttle blade adjusters. Used the Enderly linkage.
1994 Undercover Chassis 125" altered
stack injected big block, soon blown and injected
Member of The Torque and Recoil Club
[Re: Dodgeguy101]
#1183432
02/23/12 02:10 PM
02/23/12 02:10 PM
Slingshot383
St. Charles, MO.
Dodgeguy, just have aluminum welded on the tops of the runners and port to Max-Wedge size, guys have been doing that for ages.
[Re: Slingshot383]
#1183433
02/23/12 02:13 PM
02/23/12 02:13 PM
Posts: 632 MD-USA
Dodgeguy101
MD-USA
Thought I could be cheap and get a B manifold, but you are right, that is a better option.
[Re: W7_Scamp]
#1183435
02/25/12 02:14 PM
02/25/12 02:14 PM
shoebox
mckinney texas
Awesome! I always wanted the 590 but I need to keep the rpm's in Check. This 256 108 cam should drive a lil better I'd be thrilled With a 10.xx @123 with my car!
[Re: shoebox]
#1183436
02/25/12 11:38 PM
02/25/12 11:38 PM
Posts: 554 Kentucky
clovis
Kentucky
Its a simple combo that is very effective, but I still think it requires a little rpm to get it to work good. TR's by nature tend to like a little rpm. The car responded well when I moved the shifts points to 6600.
The 4200 converter hurt my car more than anything as it was always a struggle to get the car to 60ft in the low 1.50's. When I called PTC, he suggested something in the mid to high 5000 range to make the combo work better. So at the 4800 you will be a little better off than I was. Overall, I think you will like the combo and it will do what you want.
'75 Plymouth Duster Phase I 451 906/590/2-660 10.75/126 Phase II 451 Stage VI/590/1050 9.82/135 Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
