Re: well im now in the tunnel ram club- i have a question
[Re: shoebox]
#1183388
02/21/12 01:43 PM
02/21/12 01:43 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
I had a weiand a few years back & spent the $$$ to have not just that but the ports gasket matched they were off quite a bit,you might want to see how close the ports match the gaskets as well. If I did not want to invest the $$$ to pay someone to do it I would take the die grinder and only go down a inch or two and blend them in some.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: shoebox]
#1183390
02/21/12 02:19 PM
02/21/12 02:19 PM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
I really would like to do a tunnel ram. What did you have for a carb and intake? or is this a new build? What carbs are you going with?
67' charger 499 RB
10.57 at 127
[Re: maximum entropy]
#1183394
02/21/12 04:54 PM
02/21/12 04:54 PM
Posts: 2,364 PA
70HemiGTX
PA
just a clean up would prolly work wonders, and a deep port match.
That's what I did with mine.
[Re: 70HemiGTX]
#1183395
02/21/12 09:31 PM
02/21/12 09:31 PM
MRMOPAR622
Sweet Home Alabama
These intakes work great with 2 4779 carbs. with choke horns milled off sq jetted @ 80 with power valve block off on a strong 440-451 engine like yours.
[Re: shoebox]
#1183400
02/21/12 10:36 PM
02/21/12 10:36 PM
Posts: 5,620 long island NY
Ari440
long island NY
two 750s 80 jetts on a indy tunnelram
1.39 9.85 - 137 mph
[Re: Lil Demon]
#1183403
02/22/12 03:24 PM
02/22/12 03:24 PM
Posts: 554 Kentucky
clovis
Kentucky
Sometimes there is a little wiggle room between the top and base, so you might try to unbolt it and see how much movement there is before you start grinding. It would be worth a look to take the top off and set the intake on the heads to see how closely the ports match up.
As far as tunnel ram carbs for a race car, I like the 4224s (660 center squirters). They need their idle circuit leaned out, but that can be fixed with a piece of wire. For wide open use, they are hard to beat, that is why they are also popular with the boat boys. Grumpy was a little partial to them also. You can set them end to end and still get the bowls off, so the linkage is also straight forward.
'75 Plymouth Duster Phase I 451 906/590/2-660 10.75/126 Phase II 451 Stage VI/590/1050 9.82/135 Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
