Page 2 of 3 1 2 3
Re: 4-Speed Install, Muscle or Jack [Re: radar] #1182239
02/20/12 07:24 PM
02/20/12 07:24 PM
Canton, Ohio
Crazy68Dart Offline OP
Canton, Ohio
I am going to run over to HF tonight and see what they have. I think a second tool for this would be nice leaving the jack handy if needed during the process.
It is the alignment while it mid-air that is the problem, I agree.
The longer stud idea is a good one, not sure what kind of space I am going to have with an A-body tunnel. When I mocked in the car I installed the tranny/bell/block as one. Not sure I am going to do that this time with a fresh paint job in the engine compartment.
383, Hemi 4-Speed, AlterKtion, D60
Re: 4-Speed Install, Muscle or Jack [Re: Crazy68Dart] #1182240
02/20/12 07:44 PM
02/20/12 07:44 PM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
My '62 sedan also has very limited tunnel clearance. It helps to let the rear of the motor tilt downward as far as possible. I also use some threaded rod to get it lined up as close as possible.
Re: 4-Speed Install, Muscle or Jack [Re: TooMany62s] #1182241
02/20/12 08:38 PM
02/20/12 08:38 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Without a doubt, the challenge is getting the splines to line up and mesh home just right so you can stab the gearbox all the way in. I've found that rotating it back and forth and rocking the back of the gearbox in a circular motion makes it the easiest to line it up and slide it home, however, I think the long threaded rod is a great idea! get the weight of the gearbox off your hands/jack, and give you the freedom to wiggle it around while getting the splines to line up
**Photobucket sucks**
Re: 4-Speed Install, Muscle or Jack [Re: 70Cuda383] #1182242
02/20/12 08:54 PM
02/20/12 08:54 PM
IN
ahy Offline
ahy  Offline
IN
I use a jack for all the reasons posted. Bottom line its safer and easier to get lined up without hurting anything. My JC Whitney transmission jack has worked fine.
I just used alignment studs for a heavy iron transmission on a '47 Power Wagon per factory service manual guidelines. They really helped. Next time I do any transmission I'll use the studs. I made them from bolts... starting with the longest bolt that would leave clearance I cut the head off, tapered the end and ground small flats to fit a box wrench in case it was needed for removal.
Re: 4-Speed Install, Muscle or Jack [Re: ahy] #1182243
02/20/12 10:49 PM
02/20/12 10:49 PM
Canton, Ohio
Canton, Ohio
I picked up the HF jack. Looks like it will work great. I'm going to make some studs too.
Re: 4-Speed Install, Muscle or Jack [Re: Crazy68Dart] #1182244
02/20/12 11:03 PM
02/20/12 11:03 PM
Cincinnati,Ohio
jcastle1 Offline
jcastle1  Offline
Cincinnati,Ohio
I strap the 4-speed tranny onto the jack pad and wench it down with a small tie down strap.
It makes it easy to manuever,and never fall off the jack pad.
Best trick I've learned on mine anyway.
Re: 4-Speed Install, Muscle or Jack [Re: Crazy68Dart] #1182245
02/20/12 11:11 PM
02/20/12 11:11 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Seems every time I use a transmission jack, it's just a cumbersome affair, 727 or 883 I usually end up just muscling them in, whether the car is on ramps or a lift,....I'd much rather lift TKO 5spds though, they're only 115 lbs....never did weigh a 727 or 883
For the OP, if you don't muscle "heavy equipment" on a daily basis, you might be better off with a jack, just to be safe.....
Re: 4-Speed Install, Muscle or Jack [Re: Crazy68Dart] #1182246
02/20/12 11:34 PM
02/20/12 11:34 PM
North Texas
TheTieWrapKid Offline
North Texas
I'd like to put a vote in for using the cheapo transmission jack like the Harbor Freight one shown. I think mine is a JC Whitney about 70 bucks a few years back. It uses a 1/2 inch drive and has an adjustable tray with wing nuts I think. I tie it down with the provided strap and add an additional rope to hold it down good. It beats the heck out of wrestling a four speed to your chest and then up and in. And I've never tried to muscle an automatic by myself - just too bulky. Sometimes the things don't go in that easy. If you have your cheapo tranny jack, you can back off at any time and have a beer while evaluating any necessary adjustments !!
Re: 4-Speed Install, Muscle or Jack [Re: TooMany62s] #1182247
02/21/12 08:57 AM
02/21/12 08:57 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I bought one of these cheapies from Harbor Freight. I've used it for 833's five or six times. Much easier than muscle especially if your old, like me.
That is what I have, work smarter..not harder!
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: 4-Speed Install, Muscle or Jack [Re: Crazy68Dart] #1182248
02/21/12 12:34 PM
02/21/12 12:34 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
Cut a slot in the end of the studs for a screw driver in addition to the flats,it's pretty close up top.
Re: 4-Speed Install, Muscle or Jack [Re: Crazy68Dart] #1182249
02/21/12 01:09 PM
02/21/12 01:09 PM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
Use a couple of helpers or a transmission jack. I cut the end of my finger practically clean off. I got the trans down out of the car no problem (back when I is in much better shape). But then I had to set it down. It slipped and landed on the end of my finger. A bunch of gauze and a tube of neosporen, and it healed. But did it hurt for a while.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: 4-Speed Install, Muscle or Jack [Re: RoadRunner] #1182250
02/21/12 05:31 PM
02/21/12 05:31 PM
California
mickm Offline
mickm  Offline
California
i have a set of studs, and also just bought the HF jack. it will be here in 3 days! and yes, i do need to drop the trans.
i'm in good shape, and reasonably strong, but there is no way i can muscle one of those all the way in and out myself.
Re: 4-Speed Install, Muscle or Jack [Re: Kern Dog] #1182251
02/21/12 06:52 PM
02/21/12 06:52 PM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
I put threaded studs in the bellhousing studs to mount the transmission in all cars I work on. Its not for the increased clamping force, but instead for the ability to line up the trans to slide into place. It really helps!
Bingo! Long screws with the heads cut off and ground to a bull-nose (2 diagonally opposite) make a MT install child's play!
Rick
Re: 4-Speed Install, Muscle or Jack [Re: Crazy68Dart] #1182252
02/22/12 09:37 PM
02/22/12 09:37 PM
On your six o'clock
B7Satellite Offline
B7Satellite  Offline
On your six o'clock
Long screws with the heads cut off like Rick Ehrenberg said and a $50 floor jack transmission adapter from ebay.
Re: 4-Speed Install, Muscle or Jack [Re: B7Satellite] #1182253
02/22/12 11:44 PM
02/22/12 11:44 PM
Canton, Ohio
Canton, Ohio
Thanks for the tips guys. I didn't expect this thread to hang around this long...
I think this will work out great. Already nice to just move it around the garage.
Re: 4-Speed Install, Muscle or Jack [Re: Crazy68Dart] #1182254
02/23/12 08:56 AM
02/23/12 08:56 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I also used to just lift them in.Now Im too old for that.Last time I did the 0ne in my 65 I had my 3 sons help.Sure is nice to have 3 grown sons.Especially when they can do mechanical work.I knew I raised them for a reason.LOL. I also made some long studs to help guide the tranny in.Rocky
Chrysler Firepower
Re: 4-Speed Install, Muscle or Jack [Re: Crazy68Dart] #1182255
02/23/12 09:16 AM
02/23/12 09:16 AM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Sure is, I have a 100# Jeep bumper strapped to mine so I can roll it around.
2020 RAM 1500
Re: 4-Speed Install, Muscle or Jack [Re: Crazy68Dart] #1182256
02/23/12 10:51 AM
02/23/12 10:51 AM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
If they would just use a smaller rachet handle.
Re: 4-Speed Install, Muscle or Jack [Re: Crazy68Dart] #1182257
02/23/12 05:43 PM
02/23/12 05:43 PM
KS
MoparKansas Offline
MoparKansas  Offline
KS
And after you get the jack from Harbor freight you can get one of their $9.99 furniture dollies, add a a 2 x 4 and a 4 x 4 and use it to install the k-frame, engine and trans from the bottom. I have done my challenger and my brother's 67 dart this way and it worked really slick...
Re: 4-Speed Install, Muscle or Jack [Re: MoparKansas] #1182258
02/23/12 08:45 PM
02/23/12 08:45 PM
Canton, Ohio
Canton, Ohio
The way the factory intended.
I have thought about doing it this way, what is your process? You have most of the suspension removed? I thought I would have issues getting the body back down at the correct height to get the K frame bolts started.
What did you use as a lift point on the body?
Page 2 of 3 1 2 3
