Re: AN Fittings Sure Are Expensive
[Re: HEMIFRED]
#1181978
02/19/12 11:34 PM
02/19/12 11:34 PM
hit that auction site and do a search for nascar hose, nascar line and nascar fittings you can steal some used race tean stuff and they only use the best..
some prices are 1/10th the cost
Which auction site are you talking about? ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: ]
#1181979
02/19/12 11:37 PM
02/19/12 11:37 PM
Posts: 3,101 cincinnati ohio
mcat4321
cincinnati ohio
the big one
[Re: astjp2]
#1181981
02/20/12 12:17 AM
02/20/12 12:17 AM
Challenger 1
Cincinnati, Ohio
The knock offs I got from Summit/jegs/speedway all had damaged threads. They also have a different class of fit, the AN is a tighter tolerance. Also True AN fittings come from companies like aeroquip and stratoflex. Tim
Your right, most are cheap knock off fittings. True AN fittings cut into the inner liner along with the outer braid, I always heard them called cutter fittings. I'll take some pictures to show the difference tomorrow when I go to my race shop.
[Re: justinp61]
#1181983
02/20/12 12:50 AM
02/20/12 12:50 AM
Posts: 186 Middleton, ID
curleysracecars
Middleton, ID
Check out Ormes Brothers....they are in SoCal. The have everything, and know seemingly know everything about fittings and hose. Excellent guys to deal with.
Kyle Curley
[Re: astjp2]
#1181984
02/20/12 12:54 AM
02/20/12 12:54 AM
dartman366
Mt. Vernon, Ohio
actually an industrial varient of the AN is the JIC that has the tightest tolerance, all AN or JIC fittings have a 37* sealing taper and are physically inerchangeable but the tolerance variation dis allow's the inerchange, so the knock off's are a true AN but with looser tolerance's altho I would not try and use a Russel,Earls, Jegs or any intended for automotive use on a Stainless steel Swedglok intended to be used on an aircraft jet engine. ![](/ubbthreads/images/graemlins/biggrin.gif)
[Re: curleysracecars]
#1181985
02/20/12 12:54 AM
02/20/12 12:54 AM
Posts: 2,530 PA
moparacer
PA
Yep it adds up quick.
I pity you fellas that have all the plumbing with dry sump systems.
That must cost a fortune.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: moparacer]
#1181986
02/20/12 01:39 AM
02/20/12 01:39 AM
Triple Threat
Renton Washington
My car is all Earls pro-lite 350 as well, with earls fittings -10 feed, -8 return. Not cheap. Super easy to work with though.
[Re: moparacer]
#1181987
02/20/12 01:42 AM
02/20/12 01:42 AM
Posts: 2,360 Mobile Alabama
SB412DUSTER
Mobile Alabama
When I changed my car over to dry sump I bought the pump, tank and oil pan and I said to my-self the expensive stuff is over....then I started buying the fittings and hose. I spent as much on hoses and fittings as I did on the other stuff ![](/ubbthreads/images/graemlins/eeek.gif)
[Re: SB412DUSTER]
#1181988
02/20/12 02:07 AM
02/20/12 02:07 AM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
190.00 ? Don't take this the wrong way........and I sure ain't a Rockefeller........but you're getting off cheap ! ![](/ubbthreads/images/graemlins/thumbs.gif) I haven't added it up yet , and I have bought some from that auction site. But I am well north of two hunnert bucks.
[Re: justinp61]
#1181991
02/20/12 06:54 PM
02/20/12 06:54 PM
Posts: 5,080 organ
maximum entropy
organ
money well spent. i don't mind spending money on the good stuff at all. piece of mind.
[Re: jamesc]
#1181993
02/20/12 08:30 PM
02/20/12 08:30 PM
Challenger 1
Cincinnati, Ohio
imho don't bother buying house brand or unknown quality parts here. i brought summits house brand and had to send everything back and order aeroquip
Yes ![](/ubbthreads/images/graemlins/iagree.gif) I assembled some Summit AN fittings for a friend last week. What crap they were, hose clamps would be better.
[Re: tubtar]
#1181994
02/20/12 09:58 PM
02/20/12 09:58 PM
Posts: 11,689 W. Kentucky
justinp61
W. Kentucky
Yep, cheap compared to lots of other folks for sure. I'm just small fry in the pond. ![](/ubbthreads/images/graemlins/biggrin.gif)
#1181996
02/21/12 12:31 AM
02/21/12 12:31 AM
Posts: 3,428 Toronto
mshred
Toronto
another vote for them! I ordered about 200 dollars worth of push lok fittings from them. Great to deal with, and the stuff is a good quality brand for a great price too...Get in touch with Joel over there, and if your a yb member there is another discount too! ![](/ubbthreads/images/graemlins/thumbs.gif)
