Re: AN Fittings Sure Are Expensive
[Re: rowin4]
#1181966
02/19/12 03:25 PM
02/19/12 03:25 PM
Posts: 2,360 Mobile Alabama
SB412DUSTER
Mobile Alabama
How do you feel the black hose will hold up after a few years of use? Stainless braid seems to last forever, at least on the out side.
I've been running it for a little over 3 years now, it the best thing since sliced bread ![](/ubbthreads/images/graemlins/biggrin.gif)
[Re: SB412DUSTER]
#1181968
02/19/12 05:06 PM
02/19/12 05:06 PM
Posts: 6,314 The Swamp
MegaDart
The Swamp
Been using it about 5 years now and I totally agree with sb412 ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: mcat4321]
#1181970
02/19/12 06:39 PM
02/19/12 06:39 PM
Posts: 1,212 Canton, Ohio
Crazy68Dart
Canton, Ohio
It is highway robbery. Some of the house options do not have all of fitting styles available. So far I have used, Earls, Summit, Jegs, and Fragola.
383, Hemi 4-Speed, AlterKtion, D60
[Re: justinp61]
#1181971
02/19/12 08:10 PM
02/19/12 08:10 PM
Posts: 4,213 New York
polyspheric
New York
You could use steel lines and compression or flare fittings for 10% of the cost, but then it wouldn't be SHINYYYYY.
Boffin Emeritus
[Re: astjp2]
#1181975
02/19/12 10:47 PM
02/19/12 10:47 PM
dartman366
Mt. Vernon, Ohio
So far not a one of those brands is a true AN fitting. Check out genuine aircraft hardware for real AN fittings, not the knockoff stuff. Tim
so, what in your opinion is the difference between a true AN and the knockoff's??![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
[Re: dartman366]
#1181976
02/19/12 11:17 PM
02/19/12 11:17 PM
Crazy68Dart
Canton, Ohio
Sounds even more expensive... ![](/ubbthreads/images/graemlins/laugh2.gif)
